Good to lube all seals before pushing them on or in something. Engine seals too. Seals that get friction.
Not o-rings that seal facially as head, cylinder etc.
I have lubed the fork seals with fork oil. Even added some oil on the upper side to lube them, reduce friction and wear.
One thing is clear, do not use silicone grease to lube caliper seal. I made that mistake when I added an extra rotor at front on my K6.
Brake fluid really flowed all over both brakes after a very short ride.
Take it apart, cleaned with acetone and new seals.
Used brake fluid for a smioth marriage, piston-caliper. I could reuse the new pads.
I think the seal had to be flipped correctly too, one side is different if I remember correctly. I guess that can be common for piston retraction to work.
I have some extra seals after that. Added when ordering other parts. Those were very cheap at Yamiya several years ago
