Author Topic: 1976 550CB duel front disc conversion questions  (Read 1268 times)
Offline jjc
  • How do I get this bike to go forward?
Re: 1976 550CB duel front disc conversion questions
« Reply #25 on: September 05, 2023, 03:23:40 PM »
FYI
I asked earlier about the length / size of the necessary bolts to hold two discs. I was advised 110mm long. INCORRECT The length is 115mm.
J.C.
1976 550CB, 82' Honda 110T, 2000' Buell X3, 96' Yamaha 350XT, 16' Honda 450X, 2014 BMW R9T, 2003 BMW KGT,
2016 BMW 800GSA
Offline jjc
« Reply #26 on: September 15, 2023, 10:10:24 AM »
OK
My conversation plate/part has come in,but I can't find info on what size these 2 little screws are so I can figure out what drill & tap to use.
Who has the screw info. All I have been able to do is gauge the tpi,which I find to be 36
J.C.
2016 BMW 800GSA
Offline Godffery
  • Godffery's Garage
« Reply #27 on: September 15, 2023, 11:43:10 AM »
OK
That seems like a question for the suppler you got the plate from, but I use M4X0.7 flat heads for those.
 Side note: When installed, Make sure the heads are completely flush, so they will not interfere with the Speedo drive unit.
Offline jjc
« Reply #28 on: September 28, 2023, 02:52:14 PM »
Well, I have everything together but, I'm having problems bleeding the brakes.
Starting I injected fluid into each pod until fluid showed into the res. Then switched to a vac system. I now am doing nothing but cycling fluid w/o any air coming out. BUT, my lever is firm but not 'hard'. Meaning I can go to the grip, but the lever has pressure all the way.
So 1st question is - do these pots ever get hard / unable to touch the grip.
Remember I have a firm lever, but not hard & it goes to the grip.
FYI - I can see my pods slightly move each time I pull the lever.
I'm running two lines from the res to the pods by double banjo bolt with a Nisan  1/2" bore
J.C.
2016 BMW 800GSA
Offline robvangulik
  • Honda Fourever
« Reply #29 on: September 28, 2023, 03:20:36 PM »
Try riding (and braking) it, chance is that the tyre will be squealing before you pull the lever halfway.
If not, use the original 14mm master, 1/2" maybe borderline too small for 2 38mm calipers.
Offline newday777
« Reply #30 on: September 28, 2023, 05:45:10 PM »
Start by manually bleeding at the master banjo bolt to get the air lock out of the master(pump up 5-6 squeezes, hold and crack banjo bolt to release air and fluid, hold and tighten bolt. Repeat a couple more times. Then bleed each caliper. That should give you good lever and brakes.
Stu
My current rides
Prior bikes....
