Author Topic: Vacuum Gauge set  (Read 673 times)
Offline soonerbillz
Vacuum Gauge set
« on: August 29, 2023, 07:17:03 AM »
I just bought this factory Honda vacuum gauge set off Ebay.
 Not sure why they have adjustable valves on them other than possibly closing off  individual gauges for 2 or 3 cylinder engines.
 Are they necessary for synchronization of my carbs after reassembly?
« Last Edit: August 29, 2023, 07:20:09 AM by soonerbillz »
Offline Deltarider
Re: Vacuum Gauge set
« Reply #1 on: August 29, 2023, 07:35:42 AM »
They are for dampening the wild movements of the dial needles.
CB500K2-ED Excel black
Offline Scootch
  • Someday I'll know what I needed to know years ago
« Reply #2 on: August 29, 2023, 08:18:27 AM »
Before using them to sync carbs you might want to test each gauge to make sure that they all read the same..
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: August 29, 2023, 08:29:27 AM »
That’s what the adjustment is for. Hook them all together and attach to one cylinder on a running engine. Tweak them so they all read the same number. Now you can go to all four cylinders…..
Offline 38rudge
« Reply #4 on: August 30, 2023, 01:42:02 AM »
The valves are for dampening the needle fluctuations.
There is possibly a screw on the back of each dial that you adjust to get them to read the same, when they all are connect to a single vacuum source.
« Reply #5 on: August 30, 2023, 09:31:12 AM »
Offline Deltarider
« Reply #6 on: August 30, 2023, 12:35:16 PM »
This is not correct! You can not connect all 4 to one port for calibration, not at the same time. One after the other is possible however or use a stabil, not pulsating source. In that case you can connect all four at the same time.
« Last Edit: August 30, 2023, 12:55:29 PM by Deltarider »
Offline Scootch
« Reply #7 on: August 30, 2023, 12:38:47 PM »
The valves are to be used to smooth out the pulsing of the gauge needles
« Reply #8 on: August 30, 2023, 02:10:26 PM »
I used a vacuum pump - from my pond aerator - to verify/calibrate my set.
Offline grcamna2
« Reply #9 on: August 30, 2023, 04:06:39 PM »
Bench-synch style ?
Offline jgger
« Reply #10 on: August 30, 2023, 05:42:54 PM »
Bench-synch style ?
No, I'm pretty sure he means to calibrate his gages, not the carbs.
Offline grcamna2
« Reply #11 on: August 30, 2023, 06:19:30 PM »
Bench-synch style ?
Understood,thx.
« Reply #12 on: August 31, 2023, 02:29:11 AM »
Bench-synch style ?
Exactly.  I built my set myself and there was a time when I doubted one of them.  The stable vacuum resolved that.
« Reply #13 on: August 31, 2023, 03:24:19 PM »
the vacuum advance point on any car has a stable vacuum.
Offline Tracksnblades1
« Reply #14 on: August 31, 2023, 10:18:59 PM »
You’re telling your age Dave.
That means id have to get the moth balls out of one of the old L82s in the barn to sync my gauges…I use a set of refrigeration gauge hooked to a vacuum pump to bleed the vac down to 20” as the source to balance the for gauge readings.
Age Quod Agis
« Reply #15 on: August 31, 2023, 10:35:29 PM »
Ha ha yeah,im still hip to distributors and advance curves!a V8 vacuum point is super stable so long as it dont have a wild camshaft.
