Author Topic: K7 airbox 1977 CB750  (Read 702 times)
Offline beemerbum
« on: August 31, 2023, 09:34:05 AM »
Dumbest question of the year: Is this the bolt(s), if removed, that will allow the bottom half of the airbox to separate? The horizontal one of course. I'm suffering from CRS right now
Re: K7 airbox 1977 CB750
« Reply #1 on: August 31, 2023, 10:02:40 AM »
I think there is a couple vertical bolts to release the bottom of the box and filter from the top of the box(while it hangs there)
Offline beemerbum
« Reply #2 on: August 31, 2023, 01:03:26 PM »
Of course there are. Are these the bolts? Unlike earlier 750K's, the '77 has no wing nuts underneath that are obvious for removing the bottom half
Offline denward17
« Reply #3 on: August 31, 2023, 01:42:54 PM »
Yes, loosen the vertical bolts, the nut is recessed into the bottom of the filter box.  They may fall out once you loosen the bolt enough.
Offline beemerbum
« Reply #4 on: August 31, 2023, 02:25:32 PM »
Yes, of course! Thanks. I forgot the nuts on the bottom are recessed.
