Author Topic: 350F Surging  (Read 353 times)
Offline sfhurst
350F Surging
« on: September 10, 2023, 09:03:25 PM »
I just posted I have just rebuilt my '73 350F.  It starts easily, but even after it warms up and the choke is off, I cannot achieve a steady idle.  The throttle return spring holds the cable is taut, but I still can't get a smooth, even idle.  Thoughts??
Offline newday777
Re: 350F Surging
« Reply #1 on: September 10, 2023, 09:23:52 PM »
Have you checked for vacuum leaks around the rubber boots?
Have you cleaned and rebuilt the carbs?
Have you vacuum synced the carbs?
« Last Edit: September 11, 2023, 11:26:59 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline sfhurst
Re: 350F Surging
« Reply #2 on: September 11, 2023, 10:53:44 AM »
I did rebuild carbs, and do not have any apparent vacuum leaks.  I have not vacuum synched them yet.  Thanks.
Offline newday777
Re: 350F Surging
« Reply #3 on: September 11, 2023, 11:26:28 AM »
Start there. Out of sync will cause fluctuations
Stu
My current rides
Prior bikes....
Offline sfhurst
Re: 350F Surging
« Reply #4 on: October 20, 2023, 12:29:48 PM »
Got them all synch'd up using Common-Motor Collective's great one vacuum gauge tool.  Runs way better.  Thanks to all for your help.
