Author Topic: How can I test/set dwell on CB750K?  (Read 2848 times)
Re: How can I test/set dwell on CB750K?
« Reply #25 on: September 14, 2023, 03:15:49 AM »
My multimeter dwell function does not use inductive clamp. It is a clamp in the package but not for dwell.
Just connect to point and case as measuring voltage.
Dwell to get the little extra when both points are equal  when moving and adjusted on a warm engine.
Both my bikes have Dyna-S nowadays.
Too much fiddling with points.
My K6 showed strange power curves on dyno at higher revs. Frequent rebuilds, cam changes etc needed to take the plate off.
Chevy points might have been an upgrade.
Dyna-S  back where it sat before tear down. Marked with a marker pen.
I had a degree wheel on ignition side when timing the cam.
Quick check with a timing lamp to just see its OK.
My K2 got a point failure causing misfirings that made me to use Dyna-S on that too.
Might have been abused by me when wrenching, TEC points and plate.
Who knows, maybe points will return. That ignition is a part of the old CB design ;)
« Reply #26 on: September 14, 2023, 09:49:53 AM »
I would like it explained how to measure charge time of the coil from an inductive clamp on the spark leads, as some have suggested.  What specific tool does this?
« Reply #27 on: September 14, 2023, 05:34:37 PM »
If an EMP happens nearby your points Honda might be one of only few vehicles running. But if an EMP happens nearby, it will probably be one of your least worries...
