Author Topic: header temperature  (Read 1317 times)
Offline Schnell
header temperature
« on: September 14, 2023, 08:40:49 PM »
I have one of those heat sensor guns. I checked the temps of the 4 headers after a good 1/2 hour ride. I can't remember the actual temps but noted that the 2 inside cylinder headers were 30* fahrenheit hotter than the 2 outside cylinder headers. Is this normal or no? It makes sense that they would be hotter from less air cooling. I've synced the carbs, adjusted valve tappets, and the bike runs great. Is the difference okay or something to remedy?
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline Schnell
Re: header temperature
« Reply #1 on: September 15, 2023, 07:07:47 PM »
Does no one else measure their header temps?
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline beemerbum
« Reply #2 on: September 15, 2023, 08:36:14 PM »
I guess not. I'm going to try it for the fun of it. Interesting idea
« Reply #3 on: September 15, 2023, 11:18:57 PM »
subscribed
« Reply #4 on: September 15, 2023, 11:52:07 PM »
i wouldnt worry about it.
« Reply #5 on: September 16, 2023, 01:58:55 AM »
Neither would I. Realise that applying an infrared heat gun only indicate the temperature of the outer surface and one mechanic I discussed it with, told me it was not a reliable method.
« Reply #6 on: September 16, 2023, 05:50:00 AM »
With double walled stock header pipes you are not reading true temps…fwiw
« Reply #7 on: September 16, 2023, 07:51:52 AM »
Sure, with flash touching the fingers, to see if they are even across the cylinders.
Many don’t know how those cheap heat sensor guns operate.  I have one.
 The laser spot is just an aiming aid.  The actual measurement spot is below the laser spot and an inch or more wide depending on how far away the instrument is from the heat source.
Reflective surfaces can alter the heat radiation pattern among the pipes being measured.
Header pipes can be double wall and not uniform distance between inner to the outer metal layer, changing the heat transfer along its length varying from pipe to pipe.
But, if you properly use and apply the heat sensor gun under the properly controlled test conditions, it can be a fun distraction.
Offline beemerbum
« Reply #8 on: September 16, 2023, 08:52:43 AM »
You are not looking for the true temperature. You are looking for the relative difference(s) between cylinders
« Reply #9 on: September 16, 2023, 09:20:24 AM »
I have a Fluke which is fairly good, I find that shiny surfaces are difficult to get consistent readings off of.
« Reply #10 on: September 16, 2023, 09:53:46 AM »
I prefer to 'read' the color of each spark plug which tells me the condition of the jetting and how each cylinder is firing and this will also give a good indication of the color/heat those cylinders are burning:you want an even color between them.
« Reply #11 on: September 19, 2023, 12:30:17 AM »
Mark Paris in his book mentions that the two inner cylinders run hotter.  It is because of air cooling and the position in the middle of the block.  Eventually it leads to difference in shape between 1,4 and 2,3 cylinders.  I dare to say it has an influence on the header temperature, too.
« Reply #12 on: September 20, 2023, 03:41:51 PM »
Just reading this and +1 to the above. The inner cylinders have far les cooling fin surface area to aid the cooling. For sure they run hotter!
Offline Schnell
« Reply #13 on: September 20, 2023, 05:27:05 PM »
When I was active on this forum 10 years ago with another cb750, I asked if it would be smart to install cooler plugs on cylinders 2 and 3 because they receive less air cooling. Mr. Paris responded that the Honda designers had considered this and adjusted the cam for cylinders 2 and 3 with this in mind. (I think it was Hondaman, but my memory ...)
« Last Edit: September 20, 2023, 05:33:45 PM by Schnell »
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline Scootch
  • Someday I'll know what I needed to know years ago
« Reply #14 on: September 22, 2023, 06:58:26 PM »
I have recently acquired an infrared thermometer for this purpose to see if it would be useful in sorting carb etc issues. The jury is still out for me. Yes you can get temp readings but they seem highly dependent on a bunch of factors. I think the readings are somewhat subject to the surface. It is for sure a good indicator if you have a big problem with one cylinder. I don't think you can do fine tuning with it. More experimenting necessary...
Offline Kelly E
  • Geriatric Hooligan
« Reply #15 on: September 22, 2023, 08:10:24 PM »
With a Delkevik exhaust the single wall SS pipe will turn purpleish instead of gold if it's too lean. Adjust the suspect carb, a quick polish of the pipe and try it again. Just saying 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Schnell
« Reply #16 on: October 06, 2023, 10:38:22 AM »
Agree about not using this for fine tuning.
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline Kelly E
« Reply #17 on: October 06, 2023, 11:00:15 AM »
Nobody said anything about fine tuning, just an indicator of a lean condition.
1983 Honda CB 1100F
« Reply #18 on: October 06, 2023, 06:41:40 PM »
Interesting….🤔
Wonder what Honda adjusted..?
And whether it shows up when checking those cylinders against the the other with a degree wheel….?
Offline Schnell
« Reply #19 on: October 07, 2023, 06:14:31 AM »
Interesting….🤔
If I remember correctly, it was the profile of the cams for the inner cylinders.
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #20 on: October 07, 2023, 07:37:10 AM »
Kelly, may I invite you to make a video - a few seconds will do - in which is demonstrated that a leaner condition results in a higher header temperature measured by your infrared gun? Depending on the bike model you own, you can turn the airscrew to arrive at a rich and a lean condition respectively. Thanks in advance.
Offline Mark K
« Reply #21 on: October 07, 2023, 07:57:24 AM »
I checked mine a month ago or more and found my exhaust pipe temps;
#1 - 182*F
#2 - 179*F
#3 - 177*F
#4 - 108*F
Checked each one numerous times, #4 stayed pretty steady at 108*F.
Found the pilot or slow speed jet was completely clogged. So for me, reading the header temps helped me find yet another issue that had to be fixed.
'13 Yamaha FJR1300, '73 Honda CB750K3 (current project), '19 Kawasaki KLX 140G, '72 Honda CL70K3, '70 Honda SL350 (next project)
Former bikes
'74 Yamaha 60, '72 Maico 250, '74 Kawasaki 250 S1, '82 Kawasaki KZ550, '84 Honda VF700F Interceptor, '99 HD FLSTS Heritage Springer, '97 HD FLHTCUI Ultra Classic '05 HD FLHT Electraglide, '9? Buell Lightning, '03 FLHTCUI Ultra Classic,'14 Honda CRF250L
Offline Kelly E
« Reply #22 on: October 07, 2023, 07:59:01 AM »
Why do you always want to argue about stuff? I just like the resurrect old dead bikes and ride them. Not argue about it. You take the fun out of it.
1983 Honda CB 1100F
Offline Scootch
« Reply #23 on: October 07, 2023, 08:16:12 AM »
I measured my exhaust pipe temps. That's how I realized that I had a problem with #3 cylinder. Turns out there was a problem with the connection between the plug wire and the plug cap on that cylinder.
« Reply #24 on: October 07, 2023, 09:17:21 AM »
 My pipes must be too shiny for my temperature gun, I have trouble seeing the same temp on the same pipe let alone different ones.
