Author Topic: SeaFoam, Yea or Nay?  (Read 936 times)
Offline Vintageguy
« on: September 20, 2023, 11:50:34 AM »
There should be no shortage of opinion on this one; Who likes SeaFoam, and does it actually do anything? Thanks.
Re: SeaFoam, Yea or Nay?
« Reply #1 on: September 20, 2023, 11:54:45 AM »
Nay... I'm not one that buys or uses "snake oil"
Offline denward17
« Reply #2 on: September 20, 2023, 11:58:33 AM »
I'd say no, but I try to use top tier non-ethanol most of the time.
« Reply #3 on: September 20, 2023, 12:04:05 PM »
 I tried it straight to melt carb bowl varnish with no apparent result but when my lawn tractor gets gummed up, (black smoke and no power) a dose of Seafoam in the tank will have it cleared up within a few minutes of run time.
 I was sent to borrow a generator/welder but it wouldn't start, the shop tool guy gave it a dose of seafoam and cranked it a few times, then we got a cup of coffee and a shop tour and in a few minutes it started right up.
 I agree, it's not scientific and purely anecdotal evidence but it's my story and I like the stuff.  A friend uses it in his fuel injector cleaner/tester. He likes it too, used to be a VP at Holley.
« Reply #4 on: September 20, 2023, 12:28:10 PM »
Medicinal compound it is, like in this song: https://genius.com/The-scaffold-lily-the-pink-lyrics
Offline Vintageguy
« Reply #5 on: September 20, 2023, 12:42:13 PM »
For a fuel additive I have used Startron Enzyme for the past 10 years with absolutely no fuel issues whatsoever in anything from a stationary generator to my beloved bikes. That way, I also know that ethanol is well and truly out of my fuel.
« Reply #6 on: September 20, 2023, 01:14:10 PM »
I put it in fuel, late Fall. I don’t rely on it but figure it can’t hurt! Stabil is my first choice.
« Last Edit: September 21, 2023, 11:54:16 AM by BenelliSEI »
« Reply #7 on: September 20, 2023, 03:37:37 PM »
Ethanol free here with some Stabil for stored fuel. No issues
Offline Quattrocilindri
« Reply #8 on: September 20, 2023, 03:41:43 PM »
I used it in a 2002 Nissan Frontier truck, with HORRIBLE results. According to Youtubers, it would dissolve the carbon in the intake manifold and clear an EGR warning code.
However, on my truck, it apparently ruined the MAP sensor in the throttle body, resulting in a total replacement of the throttle body and $ 1100 repair bill. After that, the motor never ran as well as before.
Needless to say, I am not touching that stuff ever again.
Offline Kaze
« Reply #9 on: September 20, 2023, 03:50:40 PM »
Holy crap. I just put some in my K6 tank today. Feeling a bit less than excited now...
Offline Prospect
« Reply #10 on: September 20, 2023, 03:57:51 PM »
Ethanol free gas as well. I use it on all my bikes and boat in the fall.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline jlh3rd
« Reply #11 on: September 20, 2023, 04:08:57 PM »
google "project farms". He's a good guy, I like him. He's does comparison tests such as this.
See what you think.
« Reply #12 on: September 21, 2023, 04:24:33 AM »
Nay….
Only miracle in a can that performed as advertised, Cummins 3885737 injector nozzle cleaner used with Cummins 3885739 recirculating kit. Now discontinued of course…
John Deere Stabil works good.
 50:1 chain saw gas  “gray bottle” is what I use in my 4 stroke small gas engines year round.
« Reply #13 on: September 21, 2023, 12:34:27 PM »
 Marvel Mystery Oil unstuck a hydraulic lifter in my 86 Monte Carlo just like it did with sticky exhaust valves in my brothers Ford flatheads. The Monte had an internal intake leak that let tiny drips of coolant into the valley, when it was -10*F and an hour from home it finally let go so I knew what to fix.
 There are some snake oils that do perform a function.
Offline Flyin900
« Reply #14 on: September 21, 2023, 12:52:34 PM »
This is an oil thread in just another form. There will be every possible opinion. Some with positive results and some not so much.  ;)
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
« Reply #15 on: September 21, 2023, 01:22:52 PM »
 That's the only fact possible.
« Reply #16 on: September 21, 2023, 06:19:15 PM »
About 2 months ago my Explorer (almost 200k miles on it) started intermittently dropping the engine idle to a very slow RPM. Shutting off the engine and restarting didn't help. I got a can of Seafoam and ran it thru the gas and the problem went away in about 50 miles. That's the only time I've used it.
So far. ;)
Offline Kaze
« Reply #17 on: September 22, 2023, 12:06:50 PM »
EDIT: I'm moving my comment to a new thread.
« Last Edit: September 23, 2023, 11:11:16 AM by Kaze »
