Author Topic: Cb400f carb installation questions  (Read 895 times)
Offline soonerbillz
« on: September 29, 2023, 04:05:59 PM »
When installing the carbs and filter boot.?
 Should I install the carbs 1st,  then the filter boot?
 Or:
 Should I install the filter boot, then install the carbs?
Or:
 Should I put the filter boot on the carbs, then install the carbs and boot as a unit?
 Thanks
Offline soonerbillz
Re: Cb400f carb installation questions
« Reply #1 on: September 29, 2023, 04:32:43 PM »
It don't matter.
 These intake boots are so rock hard.. gonna put a heat gun to them.
Offline jonda500
« Reply #2 on: October 01, 2023, 06:52:04 PM »
I believe the 2nd option is it - carbs go in last. I remove the clamps off the air filter boots first so they don't get all bent up while I'm wrestling the carbs in.
John
A starter clutch thread:
Offline Mark1976
« Reply #3 on: October 01, 2023, 07:54:29 PM »
   If the the air chamber boots are as hard as it sounds, you'll need to heat them up (I use very hot water) and get them to fit the carbs first (with the carbs off the engine). Then let them cool in place, that way they'll keep their shape after you pull them off.
   I pull the air duct (oval silver tube) out of the airbox, it'll give ya that extra bit of room to slide the air chamber in (from the right side, battery side) and then push the boots (use a little lubricant) over the carb openings, then tighten the clamps. Then reinstall the airduct (a little lubricant again) and tighten its clamps. It's still a tight fit, but not nearly so, its an acquired skill.  In the future you may want to not leave the air chamber unattached to the carbs if your going to leave the carbs off the bike for any extended period of time.
« Last Edit: October 04, 2023, 06:08:20 PM by Mark1976 »
Start with the end in mind...
