SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Oil filter bolt stuck on CB500 K2, How do I get it unstuck?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Oil filter bolt stuck on CB500 K2, How do I get it unstuck? (Read 436 times)
Regor
Full Member
on:
October 05, 2023, 12:16:02 PM »
I have been trying to remove the oil filter on my CB500F. I have tried penetrating oil, heat (propane torch) and an Easy Out without success. Does someone have another idea to try to get this filter housing loose?
Logged
bryanj
Really Old Timer ...
CB500 Number 1000036
Re: Oil filter bolt stuck on CB500 K2, How do I get it unstuck?
Reply #1 on:
October 05, 2023, 12:22:40 PM »
Hammer a smaller socket onto the old bolt head 3/16 whitworth works or weld a bigger nut on to bolt head, been discussed many many times on the forum
Logged
Scott S
Global Moderator
Reply #2 on:
October 05, 2023, 04:23:13 PM »
The fact that you say Easy Out implies you've already broken off the head of the bolt?
Logged
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
dave500
WHAT?no gravy?
Reply #3 on:
October 06, 2023, 02:46:34 AM »
if you still have any head on that bolt,the best way is to carefully with a punch or chisel knock in the undo direction that bolt either on the head or better the big flange under it.
Logged
rotortiller
Expert
Reply #4 on:
October 06, 2023, 03:55:50 AM »
The best thing to use is a six point socket so the head does not get chewed. For some reason people think this bolt needs a lot of torque when installed. If it will not come off you will have to blast lol. Maybe use a hole saw to cut around the bolt when all else fails and then perform careful surgery.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
