I got washers with an aftermarket heavy duty clutch in the 80's.
It had +1 fiber and 1 metal disc. Thinner fibers.
I saw that the early CB750 had washers under the springs.
CMS -69 chart.
I have had thoughts about that part with those weak looking towers for springs. Does not look strong enough.
I did not break any in my K6 with 836cc 80Whp.
Now 970cc, last dyno soon 1 year ago 107.5Whp DIN.
Carbs got correct needles after that so it runs better. Maybe not at top power 8000-9500rpm.
F2 clutch with double metal disc and extra hard Barnett springs. For CB550 and the smaller.
It slips with std Barnett for CB750 despite glass beaded metal discs.
The outer part with bearing is a stronger billet type.
But those towers still stock weak looking type.
Can a PO had assembled clutch wrong so the bottom part does not fit into the splines?
50% chance to get it wrong if not verified at assembly. Tighten clutch when wrong can crack it?
Good to test first and use marker pen on one tower and beside the hole it fits.
Barnett springs are longer. Almost 37mm.
Measured 36.9mm golden spring. Has been used during one ride where I got sudden slip after 3000rpm, before 4000 on 3rd gear. 17:48 gearing. Felt like sudden wheel spin. Earlier this year when I thought std Barnett should due.
Black, the stronger 66 lb model, gold CB750 56 lb
I lubed clutch cable that helped my office working hand to handle those hard springs during a longer ride with frequent use of clutch.
