Author Topic: 1976 CB750 Carburetor Sysc  (Read 390 times)
Offline John G
  • A 1975 CB Rebuild
« on: October 08, 2023, 04:13:13 PM »
Is there a non adjustable carb on the 1976 CB750 or do you just adjust all of them while using a synchronizer tool?
John G.
Online newday777
Re: 1976 CB750 Carburetor Sysc
« Reply #1 on: October 08, 2023, 06:25:14 PM »
No not until 1977 with the PD Carbs. Roundtops have 4 adjustable.
Stu
My current rides
Prior bikes....
« Reply #2 on: October 08, 2023, 07:32:24 PM »
The "baseline" carb has always been specified (and works as) #2. Even the old Honda manuals (that showed how to do it) stated to leave #2 as the starting point, adjusting the others to it accordingly. In the early 750 it was cheaper to leave the molds alone for all of the carbs: in the 1977 versions the US DOT forced Honda to make it impossible to "misadjust" the baseline carb during carb-sync operations. That's when the unadjustable #2 carbs first appeared.
« Reply #3 on: October 08, 2023, 09:41:08 PM »
One fixed carb make it impossible to bench sync all too high ending up in a too high idle and do it again, properly.
