Author Topic: Solved: Warming up the 750K, throttle stop screw tending  (Read 2628 times)
Offline Kaze
« on: October 10, 2023, 09:13:47 AM »
I start my CB750K cold with a little choke and tend the throttle for a second until I get my throttle stop screw where it needs to be in order to hold it at about 2 grand. I idle at 2 grand until it's warm. When the engine warms up and the idle climbs (as it does) I back off the throttle stop screw and idle more like 1000 to 1100rpm.
Is babysitting the throttle stop screw just a fact of SOHC4 CB750K riding? I think so. But then, I don't sit there holding the throttle until it's warm. As soon as the bike is started and my gear is on, we go.
Guys who rode the bike when it was still new in 197x, same deal or not?
EDIT: This topic was apparently covered in "Warm up and idle speed what's normal?"
« Last Edit: October 11, 2023, 08:17:48 AM by Kaze »
One man's rubbish is another man's project.
Re: Warming up the 750K, throttle stop screw tending
« Reply #1 on: October 10, 2023, 09:51:03 AM »
 Yup, there is no fast idle system on the early 750 choke, my 78 GL1000 has it, which seems odd after being used to 750's forever.
Online PeWe
« Reply #2 on: October 10, 2023, 10:27:28 AM »
My Mikuni carbs on the K6 has fast idle with choke. 2500 rpm and more.
A little bit irritating. Race carbs.
My K2 CB 750 carbs better in that manner.
Idle adjusted when really warm, 1200 rpm wich make rides easier.
Choke on when starting, off after 10sec. It can idle now.
This is the 064A carbs. Shipped with CB750 F 1975 according to Shop manual.
The stock K6 086A need a little choke on for a little longer. Different needle, leaner than 064A.
The older Mikuni VM29 have variable choke with increased idle.
« Last Edit: October 10, 2023, 10:31:32 AM by PeWe »
Offline carnivorous chicken
« Reply #3 on: October 10, 2023, 10:54:36 AM »
There was a conversation that included this recently, elsewhere on the forum. Either the screw or the grip are the two ways to feather the idle until it gets warm. I prefer the grip so I don't have to reach down and tweak the screw, just seems easier to me, and then I know with the screw in the same place it'll find its idle. But six of one, half a dozen of the other.
« Reply #4 on: October 10, 2023, 11:12:22 AM »
"throttle stop screw"
Is this the screw under the grip(pre K5 1975) or the idle adjustment on the carbs????
You chose to leave off the actual year of which you want to know about. (197x) you have left too much out of the equation.
« Reply #5 on: October 10, 2023, 12:31:20 PM »
I keep the idle screw/stop on the carbs clean and well coated threads (anti-seize). It’s so easy to reach in and adjust it that I usually turn it up a bit (once the choke is off) and then drop it down before setting off. Part of owning a SOHC Honda.
Offline jonda500
« Reply #6 on: October 10, 2023, 02:31:19 PM »
Don't know why Honda discontinued the screw in the switchblock under the grip that the older models have - I use that screw to hold the throttle open a little for a few minutes while I put on my helmet and gloves, after which it will just barely idle without stalling at around 1000rpm and I release the screw before taking off. Maybe Honda was worried about folks using it as a cruise control?
John
A starter clutch thread:
« Reply #7 on: October 10, 2023, 03:12:51 PM »
Do you know what pressure the oil filter bypasses cold oil..
Man, 2500 seems high on a cold morning with 20w-50.. that would peg a gauge on an old unmolested  F1….
Offline Kaze
« Reply #8 on: October 10, 2023, 03:31:40 PM »
Vocabulary...
I say "Throttle Stop Screw" for the large, ridged screw on the end of the carburetor that controls how low your idle can go. Left side until K4, right side from K5-8. I used to call it the "Idle screw" but people kept thinking I was talking about the idle mixture / air screws. Is there an official term for this screw? "Gear preparation time screw"
"Feathering" the throttle is new to me. I get it by context of course. Fun term.
DonR and Pewe: Is your fast idle system electronic?
Carnivorous Chicken: I saw that thread but couldn't track it down. That's the one where Benelli said "Part of owning a SOHC Honda."
NewDay: In this case, I didn't think the year mattered, since all years from K2 to K7 were the same deal for me. I set the throttle stop screw on the end of the carbs and put my gear on, turned it down when the bike was warm.
K2... my switches weren't stock so I didn't have that. I also didn't have the winker-beeper kill switch on the bottom of the left grip.
K4... Now that you mention it? I never used that screw by the handlegrip on my K4. I remember seeing it and thinking something like, "That's a goofy little knob" and went on my merry way. I was too young and too busy to care about things like that. ;) Good times.
« Last Edit: October 10, 2023, 03:37:10 PM by Kaze »
« Reply #9 on: October 10, 2023, 03:48:11 PM »
 The fast idle on a gl1000 is linkage operated.
  If a guy was inclined to use a set of 77-78 PD carbs, he could adapt a fast idle solenoid from a 750 Hondamatic. Don't ask me how. I've never done it, I've only heard of the F carbs being put on an A and retaining the A's solenoid.
« Reply #10 on: October 10, 2023, 03:59:37 PM »
I thought the Auto’s solenoid ran a vacuum slave to actually do the work..?
In the autos case to increase the idle when it was in gear idling against the torque converter. Then once back in neutral dropping the idle speed back to the same rpm as in gear. If properly adjusted it would idle near the same rpm in gear against the converter or in neutral..?
Offline Kaze
« Reply #11 on: October 10, 2023, 04:15:58 PM »
The cool thing is, if I ever get one of the earlier year CB750s, I will know what the "funny little screw" is.
Don: Your 69-70 750s have the idle / throttle stop screw on the carbs too, correct? (I would assume, but better not...)
If they weren't so expensive, I'd like to get a 70 just to explore it. But, too late. :)
Hondamatics...alien tech.
Offline flybackwards
« Reply #12 on: October 10, 2023, 04:36:47 PM »
This is the previous thread that I started:
http://forums.sohc4.net/index.php/topic,193574.0.html
« Reply #13 on: October 10, 2023, 04:57:58 PM »
 Nope, no screw on a set of 4 cable carbs, at times I adjust the single throttle housing cable near the right control. The K1 Hot Rod's 29 Mikunis have an idle screw but it's way up in there and difficult to reach. K2 has the screw, as does my brothers K4.
Offline Kaze
« Reply #14 on: October 10, 2023, 05:29:30 PM »
(EDITED)
Don: Wow. This is exactly why I almost always might say "K2-K8" when talking about this bike, (as opposed to 69-K8) because those first ones are like unicorns compared to horses. "But... it's a horse?" "Well yes, but it has a horn and grants wishes." "Wishes?!" "Okay I lied about the wishes."
Flybackwards: There it is! Thanks. That's the "scary" thread that talks about bent spark advancer shafts... That's probably why I couldn't find the thread. I was hiding under my bed after reading it.
« Last Edit: October 11, 2023, 06:47:34 AM by Kaze »
« Reply #15 on: October 10, 2023, 06:20:29 PM »
American Honda was threatened with a lawsuit (by the US DOT, again) in 1973 about the "cruise control screw" on the right (throttle) grip.
As it turned out (after Honda removed the screw) it was a former HD employee who had obtained a job within the DOT who sent the letter to Honda on the DOT letterhead: in other words, it wasn't "official".
Rumor had it that he 'left his position' (fired?) at DOT after this story got out in 1976 (it may be been 1977...). I only remember it because of how many of the 750 riders who had 'traded up' to a newer one were trying to find ways to add it back because we ALL used it for 55 MPH riding: this was when the gigantic Cruise Control mechanisms appeared in the marketplace to fill in the void. We've seen a few of them on 'barn find' bikes here in the forums.
Online PeWe
« Reply #16 on: October 10, 2023, 08:03:58 PM »
That is something to have in mind. Oil filter spring and when it will let filter move and bypass oil. Oil pressure gauge show +60PSI at idle.
I think I have seen closer to  80PSI.
My bike is parked in the warmest part of the house, the garage.
Never lower than +21C.
I let it idle for 30 sec before take off, use clutch to glide away. The mechanical choke off a few minutes later.
Engine need to be fully warmed up before initiated use of throttle. I feel when clutch lever get more play when warm.
« Reply #17 on: October 10, 2023, 09:48:34 PM »
 I was looking at a bypass today, I have an aftermarket filter housing and matching big head bolt that currently has no bypass in it. I found an old stock bolt that's mostly rounded off to swap the bypass valve from. It was surprising to me how easy the valve moved when pushed with a small screwdriver.
 Caution: oil related car engine story,
A couple years ago our big block chevy lost a rocker arm needle bearing, the tiny needles went into the oil pump and some material made it into the rear two main bearings, yet when I cut the oil filter open it was clean inside. I could only conclude that the stock type K&N oil filter media, high flow billet pump and heavy oil was keeping the bypass open a lot.
« Reply #18 on: October 10, 2023, 10:00:35 PM »
Interesting, indeed!
Honda says the oil filter bolt is supposed to bypass at 21 PSI. But...aftermarket oil filter bolts fit several other bikes (like Kawi KZ1000) that have much, much lower pressure bypass numbers (I think the KZ1000 MAIN oil PSI is only 30?), so you might have to take the Honda spring out of the old bolt and use that instead?
« Reply #19 on: October 10, 2023, 10:38:55 PM »
 Actually, the aftermarket bolt currently has nothing inside except the roll pin that holds the bypass valve in, so I was going to use all of the Honda bolts internal parts. I'm a little wary of it but it's all chrome and I have a project K2 that I was planning to bolt all of the chrome to that I removed from other bikes.
« Reply #20 on: October 11, 2023, 04:03:11 AM »
Don: Wow. This is exactly why I almost always say "K2-K8" when talking about this bike, because those first ones are like unicorns compared to horses. "But... it's a horse?" "Well yes, but it has a horn and grants wishes." "Wishes?!" "Okay I lied about the wishes."
Be careful on bunching years together like your 'K2-K8' together statement as there are so many changes in those years, on many aspects of the SOHC 750s, especially concerning the carbs and choke concerns of this thread of yours, roundtop carbs of K2-K6 changed out on K7 to PD carbs(totally different animal!).
The throttle stop screw on the hand control was only on K2-K4.
I so wanted the throttle stop screw on my new K5 and K6  back in 75 and 76 that while I was parts manager, I spent some time trying to figure out how to change the controls to the K4, but I hadn't learned enough about the wiring differences between the years(I was only 20 years old at that time....), so I just opted to put on one of the 'big aftermarket throttle lock' cruise controls that I had ordered in to sell over the counter. I wish I knew then what I know now.......
Offline rotortiller
« Reply #21 on: October 11, 2023, 04:15:17 AM »
After 1973 the throttle friction was removed from the Kawasaki H2 Triple however there were no stories about a Fergy guy being at the heart of it. I liked that throttle feature on long trips, especially so for a CB750 with its stiff return spring.
« Last Edit: October 11, 2023, 09:50:52 AM by rotortiller »
« Reply #22 on: October 11, 2023, 05:07:35 AM »
Stock sbc and bbc start by-passing  @ 17 psig and are fully open @18psig..
Both their bypasses would bypass with a 17 psig or greater differential from the outside of the filter to the inside…so if you had 60psig of oil pressure but your main bearing oil galley had 40psig because of a partially plugged oil filter or cold oil, your bypass was bypassing a percentage of oil around the filter media going straight to the oil galleys…
Most racers would pipe plug the factory bypass and would run two quart ACDelco tandem truck 427 tall deck oil filters.
A high volume big block oil pump mounted on a tight clearance SBC would still kick the big oil filter’s oring out on a cold morning with a premature throttle jazz even using 10w30 oil..
But when following the 10psig of oil pressure per 1000 rpm gospel back then, you didn’t worry about idle and cold oil..
You just needed 70psig for 7000rpm and 80psig for 8000rpm..at the rods and mains..
« Last Edit: October 11, 2023, 05:42:03 AM by Tracksnblades1 »
Offline Kaze
« Reply #23 on: October 11, 2023, 06:29:13 AM »
Be careful on bunching years together like your 'K2-K8' together statement as there are so many changes in those years.
Figures somebody would bust me on that wording...
My comment was more about pointing out that I rarely add 69-71 to my discussions. I've edited the text.
« Last Edit: October 11, 2023, 06:48:47 AM by Kaze »
Online PeWe
Re: Solved: Warming up the 750K, throttle stop screw tending
« Reply #24 on: October 11, 2023, 10:54:17 AM »
Interesting discussion.
So the oil filter bolt will bypass oil during normal use?
Normal cruising when warm, pressure around 40PSI.
I thought that bolt bypass valve should let oil outside filter when filter was so clogged that oil will not pass, or at least not enough to lubricate.
Oil with particles better than no oil.
