Author Topic: Rear Brake Pedal Angle  (Read 440 times)
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« on: October 12, 2023, 06:10:10 AM »
I'm almost there ... almost!
I'm trying to adjust the rear brake pedal and spring. The first issue is that the pedal either sits too high or hits the exhaust when depressed.
Looking at the return spring, and having seen several related posts, it all looks to me a bit loose; the spring that is. I have the spring positioned as in the photos, which I think is correct.
The first photo is with the actuator rod loose to show the position of both ends of the spring (one covered by rubber tube) and the second is with the rod "tight".
Can anyone confirm the spring is correctly located and then advise how to position the brake pedal, using the split in the lever as a reference; I currently have it at about 10 o'clock.
Thanks.
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline jonda500
Re: Rear Brake Pedal Angle
« Reply #1 on: October 12, 2023, 03:33:14 PM »
Are you using the rubber tube to protect the frame paint? Never seen that before.
Honda provides a little centre punch dot on the brake pedal and another one on the edge of the end of the shaft, if the dots line up you have it right! Ten o'clock sounds close. The actuation lever and spindle at the rear end also have these dots - on my bike I have the lever one spline tighter than the dots suggest so I don't have to have the adjuster done up so far to have a nice tight pedal,
John
A starter clutch thread:
Offline newday777
« Reply #2 on: October 12, 2023, 11:32:26 PM »
On what bike??
Stu
My current rides
Prior bikes....
