Author Topic: Finally put the carbs back on  (Read 698 times)
Offline Mossy
« on: October 18, 2023, 11:21:58 AM »
I finally finished the rebuild and bench sync of the carbs on my CB350F.
After doing a vacuum sync I shut it down to let it cool off a bit.
I fired it back up and it started immediately but it wants to rev at about 4000 rpm. The idle screw isn't touching so it's not that.
What I did notice is when I push down on those brass caps on top of the carbs it idles down to 1800 but when I release them the rpm goes back up.
Is there an adjustment I'm missing or what do I do to correct this situation?
Thank you
Offline denward17
Re: Finally put the carbs back on
« Reply #1 on: October 18, 2023, 01:00:56 PM »
I think you adjusted the slides too high in the initial setup.  Did you bench sync them first?
Offline Mossy
« Reply #2 on: October 18, 2023, 01:30:28 PM »
Yes, I did bench sync them.
Offline denward17
« Reply #3 on: October 18, 2023, 01:35:11 PM »
What did you use as a guide and on which side?
Offline Mossy
« Reply #4 on: October 18, 2023, 01:37:59 PM »
I used gage pins and adjusted all of the slides the same. I have the old style carbs so there is no reference carb.
Offline Johnie
« Reply #5 on: October 18, 2023, 03:06:29 PM »
Agreed with denward. You need to bring all those slides down a bit. Then sync again.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Online Mark1976
« Reply #6 on: October 18, 2023, 03:09:47 PM »
Post a pic of the sync adjusters...
Start with the end in mind...
Offline Mossy
« Reply #7 on: October 18, 2023, 03:30:33 PM »
Thanks Johnie. Mark, I'll post a pic in a sec.
Offline Mossy
« Reply #8 on: October 18, 2023, 03:34:36 PM »
Carburetors
« Last Edit: October 18, 2023, 03:50:13 PM by Mossy »
Offline Kaze
« Reply #9 on: October 18, 2023, 03:52:55 PM »
Sorry to barge in... what are "Gauge pins". Thank you.
Offline Mossy
« Reply #10 on: October 18, 2023, 03:56:57 PM »
Gage pins are precision pins that you use to check hole diameters. I did inspection for a living for some years and used them daily. I have complete sets that range from .005 up to .500 by the .001
This is one set that I have.
https://www.grainger.com/product/39UF10?gucid=N:N:PS:Paid:MS:CSM-2295:TVRYAD:20501231
« Last Edit: October 18, 2023, 03:58:48 PM by Mossy »
Offline sevenfiveohhhh
« Reply #11 on: October 18, 2023, 04:04:58 PM »
Could be as simple as a cable adjustment- the adjuster screw needs to touch the rack so it can do its job. Check all the adjustment points, if you can't get any slack there, I would say start over and shoot for more vacuum- adjust each slide so it closes a bit more. It should reach a point where the idle screw starts to be effective.
CB750K5 Planet Blue
CB750K3 Sunrise Flake Orange
CB750K2 w/K1-Candy Garnet Brown paint
CB750K2 Trustyrusty Briar Brown Metallic
Offline Mossy
« Reply #12 on: October 18, 2023, 04:13:57 PM »
Seven, you're saying adjust the slides on the bike or start over with a bench sync?
Online Mark1976
« Reply #13 on: October 18, 2023, 04:30:58 PM »
 Those sync screws are too far out, prior to your initial disassembly you should take note of them. Generally they're only 2 turns or so exposed, it appears you've got 4 or more showing. Try using a smaller drill on the intake side of the slide when doing your bench sync. Back out the idle adjustment screw a turn or so as well.
« Last Edit: October 18, 2023, 04:33:00 PM by Mark1976 »
Offline Mossy
« Reply #14 on: October 18, 2023, 04:37:02 PM »
Thanks Mark. I'll pull them back off tomorrow. I'll let you know how it goes when I get done. I appreciate all of the help from all of you.
« Reply #15 on: October 18, 2023, 04:40:34 PM »
Yes, like Mark said, start with the slides all closed more, I usually use a very small gauge- like a paperclip, maybe 1/16 drill bit. That should get you to a point where you have to use the idle adjustment screw.
CB750K5 Planet Blue
Offline Mossy
« Reply #16 on: October 18, 2023, 05:09:05 PM »
Will do. Thanks again to all of you.
Offline WhyNot2
  • I'm finally an
« Reply #17 on: October 18, 2023, 05:56:00 PM »
I did exactly what they are telling you, and couldn't ask for a better riding bike.
Haven't vacuum sync yet, but ran like a charm.
Offline carnivorous chicken
« Reply #18 on: October 18, 2023, 06:28:59 PM »
For the record, no need to pull them if you've already got the air filter hooked up and you've got a sync tool. If they're still sitting like they are in the photo might as well, but it is a royal PITA once you've got the airbox assembly hooked up. And yeah, the adjusters are way oo far out...
