Author Topic: Stud and bolt information please  (Read 611 times)
Offline suewoo
« on: October 27, 2023, 02:20:37 AM »
Could anyone please tell me what the pitch is on the 8 x 22mm exhaust studs? Also what is the measurements of the long bolt that holds the 2 standard exhausts to the frame? We are working on fitting replica 341 pipes to our Rickman frame so nothing to work off!
Re: Stud and bolt information please
« Reply #1 on: October 27, 2023, 04:12:37 AM »
Why did you post this in the 750A Automatic section? You don't have an automatic motor in your Rickman do you??
Offline Alan F.
« Reply #2 on: October 27, 2023, 08:49:55 AM »
I don't see a length listed, but I'm sure you can take off a few millimeters if you're not mounting passenger pegs.
https://www.cmsnl.com/honda-cb750k6-four-england_model14383/partslist/F16.html
Offline Nurse Julie
« Reply #3 on: October 27, 2023, 10:45:09 AM »
As you're in UK, if you also join us on the UK Forum, if you haven't already, I'm sure there will be members that may help answer your questions. I'm sure we have members with Rickmans.
www.sohc.co.uk
« Last Edit: October 27, 2023, 10:46:54 AM by Nurse Julie »
Trust me I'm a Nurse, I promise it won't hurt....much
« Reply #4 on: October 27, 2023, 01:31:47 PM »
Here you go on the rear bolt
Starts out as a 14mm bolt total length of 148mm, tapers down to 12mmx1.25 thread for 20mm
Offline suewoo
« Reply #5 on: October 27, 2023, 02:40:13 PM »
Many thanks
