Author Topic: Adjusting cam chain tensioner - with mounted sidecar.  (Read 381 times)
« on: October 28, 2023, 02:07:26 PM »
Red developed some slight hickups, so I took off the tank and carburetors to do some cleaning.  I have subsonic cleaner on the way and want to make them carbs nice and shiny  ;D
I also took off the tensioner.  Turns out the holding M6 bolt was stripped and did not keep the plunger in place.  I replaced the bolt and put the tensioner back, but with the sidecar I am unable to follow the points plate and set it at 15 degrees past TDC.
Before I start messing with lights and mirrors, any ideeas?  Over my points plate is Pamco ignition, therefore I really have to look straight in and with a light.
Taking the hack off is the last option and it would likely make me drink.   ;D
Offline Killer Canary
  • Typical Bran Muffin
Re: Adjusting cam chain tensioner - with mounted sidecar.
« Reply #1 on: October 28, 2023, 02:23:21 PM »
Never mind the bike and just drink?  ;D
Kawi GPz900, H1
« Reply #2 on: October 28, 2023, 03:48:50 PM »
Since this is not timing of the spark, I think I will use a stick in spark plug hole "4, bring it all the way up and use timing wheel to measure 15 degress after that.
Thoughts?
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: October 28, 2023, 06:38:35 PM »
Thoughts?
Should work just fine, for what you are doing.
