Author Topic: Does anyone know how to get this off of engine parts?  (Read 1174 times)
Offline KV41
« on: October 30, 2023, 02:14:54 PM »
I recently opened up an engine that looks like it has been sitting forever. I've tried alot of things to get off this coating of (what I think is dried/burnt oil). I'm not sure what the previous owner had put in there or had done to but it is on everything inside of the engine. Any tips to getting this off?
Thanks,
KV
« Last Edit: October 30, 2023, 02:17:40 PM by KV41 »
Re: Does anyone know how to get this off of engine parts?
« Reply #1 on: October 30, 2023, 03:29:54 PM »
 There was a Hondaline oil that contained large amounts of graphite. I have an engine like that, I always thought it was carbon from a plugged exhaust (which it had) Hondaman mentioned that he used to see that.
 I'd try scotchbrite and solvent.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: October 30, 2023, 06:02:07 PM »
Vapour blast.
Offline Tracksnblades1
« Reply #3 on: October 30, 2023, 07:08:07 PM »
Karcher hot water high pressure washer….clamp it down…😁
Tyme Carburetor cleaner…submerge for 1/2 hour or more, rinse off with water…😁
Age Quod Agis
« Reply #4 on: October 30, 2023, 07:31:59 PM »
Yeah, like Don R said: it had Hondaline oil in it at some point, or so it appears.
It turned the inside of my own K2 jet-black in 3 oil changes! I tore the whole thing down and had the parts washed by the local machine shop in their parts washer: that did it.
« Reply #5 on: October 30, 2023, 07:45:34 PM »
« Reply #6 on: October 30, 2023, 09:01:51 PM »
Vapour blast.
Or just bead blast
I wouldn't bother with either method, just to make internal parts look prettier. ;)
Offline KV41
« Reply #7 on: October 30, 2023, 09:28:39 PM »
@hondaman is it ok to run as is? It’s not going to hurt anything? I vapor blasted the cases, head and cylinder so those are clean of the Honda line residue. Only some of the  components like the transmission, clutch and now have it
« Reply #8 on: October 30, 2023, 11:47:20 PM »
Castrol Super Clean is highly alkaline cleaner and parts soaked in it if clear coated by Honda it breaks it down and strips that clear coat, so I would bet this would also be stripped. Definitely wear gloves and work outside with this stuff. It gives me an instant raging migraine if I catch too much of a breath of it.
Rinse well and brush/scrub the parts with a nylon detail brush to ensure the residue is gone.
David
« Last Edit: November 01, 2023, 07:15:07 PM by RAFster122s »
« Reply #9 on: November 01, 2023, 07:02:30 PM »
 Super clean will etch aluminum if left on, (as David said) it also took the brushed aluminum finish totally off my GMC plumber trucks dash. Oops.
« Reply #10 on: November 01, 2023, 10:03:37 PM »
  I doubt that it will hurt anything, it's a graphite lubricant which Honda apparently used an abundance of in the earlier oil.
  I almost junked an 811 engine because it was so black inside, I thought it was carbon from the plugged exhaust it had when I got it. A percentage of it may have been carbon, I don't know.  It's been under the bench for years and when Mark mentioned that oil, the little light bulb over my head lit up.
