Author Topic: CB7750 engine serial number  (Read 927 times)
Offline Mark K
« on: November 06, 2023, 07:54:39 AM »
Picked this up over the weekend, confused about what year model engine it is. Checked a couple different websites (and here). I believe it's out of a '76 bike, just want to make sure.
Engine serial # CB750E-2513331
Any help is appreciated,
Thanks,
Mark K
'13 Yamaha FJR1300, '73 Honda CB750K3 (current project), '19 Kawasaki KLX 140G, '72 Honda CL70K3, '70 Honda SL350 (next project)
Former bikes
'74 Yamaha 60, '72 Maico 250, '74 Kawasaki 250 S1, '82 Kawasaki KZ550, '84 Honda VF700F Interceptor, '99 HD FLSTS Heritage Springer, '97 HD FLHTCUI Ultra Classic '05 HD FLHT Electraglide, '9? Buell Lightning, '03 FLHTCUI Ultra Classic,'14 Honda CRF250L
Offline rotortiller
Re: CB7750 engine serial number
« Reply #1 on: November 06, 2023, 08:35:40 AM »
That's a funky looking starter cover.  :)
Offline 69cb750
« Reply #2 on: November 06, 2023, 08:45:22 AM »
CB750E-2513331 is 1975 F engine
« Reply #3 on: November 06, 2023, 08:48:33 AM »
The model guide shows the engine serial numbers...
http://www.sohc4.com/cb750/cb750f/#serial-numbers
Online newday777
« Reply #4 on: November 06, 2023, 09:19:38 AM »
Probably was in a chopper and those are start button and???
Offline Mark K
« Reply #5 on: November 06, 2023, 11:43:58 AM »
Along with the toggle switch, there is a key switch, (ignition?) on the starter cover.
Former bikes
Offline Mark K
« Reply #6 on: November 06, 2023, 11:46:20 AM »
That's what I thought too, but the number doesn't fit into the model guide, (Stev-o posted a link), I had looked there, but because the number didn't fit, I thought I'd ask the experts here.
Former bikes
Offline Mark K
« Reply #7 on: November 06, 2023, 11:47:35 AM »
Thanks Stev-o, I had looked at the guide and the number didn't "fit" in the range of numbers.
Former bikes
Offline Mark K
« Reply #8 on: November 06, 2023, 11:49:08 AM »
[/quote]
Not sure what it came out of, guy I bought it from found it in a building he was cleaning out for a friend. He didn't have any history on the engine.
Former bikes
Offline 69cb750
« Reply #9 on: November 06, 2023, 04:10:25 PM »
25115085 - 2500004 = 22,615,081 22 million engines !
Chart is incorrect, your engine is in 22 million range.
« Reply #10 on: November 06, 2023, 04:24:57 PM »
It looks to me like a 1975/6 750F0.
« Reply #11 on: November 06, 2023, 05:01:33 PM »
If an F motor then it has some special things to watch out for given the F motor had some teething issues, right?
« Reply #12 on: November 06, 2023, 07:39:15 PM »
+1 on the 75 750F engine. Bottom end anyway. Does the head have 392 on the top fin of the head backside between 2 & 3? That would also indicate 75 top end
« Reply #13 on: November 06, 2023, 07:41:12 PM »
         Then the guide is wrong
« Reply #14 on: November 06, 2023, 07:43:36 PM »
The 75/76 F engine had NO teething issues. It is a good update engine.
Online newday777
« Reply #15 on: November 07, 2023, 01:54:30 AM »
Not the 75/76 F that this thread is about (though the motor could have a later head on it if it was modified at some point in it's lifetime and we didn't get that from this information given)....
77/78 F2 heads, yes(valve guides).
You need to be careful with specific information and not just say F had teething issues.....
Offline jlh3rd
« Reply #16 on: November 07, 2023, 05:22:02 AM »
Thanks,
Mark K
from this book, this is what you have
a 1975 750F
Offline jlh3rd
« Reply #17 on: November 07, 2023, 05:34:35 AM »
 and ...as discussed on here before.
It appears the '75 F model was only around for 2-3 months before the '76 F debut.
makes the bike/ motor kinda ...rare ?
« Reply #18 on: November 07, 2023, 08:19:55 AM »
The 77F2/78F3 also had extra-strong valve springs with extra-weak top spring retainers, which caused their infamous reputation for 'dropping' a valve when the cotter keys pulled thru the simple stamped-steel retainers. Ken a CycleX has a solution for this issue that I install in every F2/3 head that comes my way: super-strong top spring retainers. Worth every cent.
Offline Mark K
« Reply #19 on: November 07, 2023, 04:20:35 PM »
Thanks HondaMan.
Former bikes
Offline Mark K
« Reply #20 on: November 07, 2023, 04:27:36 PM »
Thanks Jerry. I had my son-in-law help unload it and I stowed it under my work table for now. Have to finish up my current project. But I will check for the '392' when I get a chance. My plan is to put the engine in a '73 frame I acquired about a year ago, (future project).
Former bikes
Offline Mark K
« Reply #21 on: November 07, 2023, 04:31:22 PM »
Thanks,
Mark K
a 1975 750F
Thank you, I trie to find that book as a PDF download, no luck.
Former bikes
« Reply #22 on: November 07, 2023, 07:33:36 PM »
Mark, I have a spare one under my work bench too  ;)
Just a FYI. The 75 ran from 1/75 through the first week of April. 15054 only. But the engine was the same in 76. A total of ~ 54,000 were produced.
Offline jlh3rd
« Reply #23 on: November 08, 2023, 04:13:28 AM »
Thanks,
Mark K
a 1975 750F
I bought one last year for my son from HELMS. With tax and shipping it ended up around $80.  Last time I checked they still had some.
HELMS is a quality OEM manual manufacturer.
« Last Edit: November 08, 2023, 04:58:09 AM by jlh3rd »
Offline Mark K
« Reply #24 on: November 08, 2023, 05:28:03 PM »
Thanks for the info Jerry.
I have a '70 SL350 I bought about a year ago. Disassembled it and it now resides in a large cardboard box in the garage, except for the frame, wouldn't fit in the box  ;D has a CL350 engine. Need to get started on that one sometime.
Former bikes
