Engine is just about ready to go in. The clutch, alternator and gearbox covers have been vapour blasted. I think I’ll pull them off when the engine is installed and give them a real polish. The chrome cam cover is not perfect, but it will look fine once the engine is buried in the frame. The side covers should match.
If you look closely you might spot two bolts (both grade 8 hardware, 3/8” and 7/16” X about 6” long). They are covered with old heater hose. Since both these right side engine mounts bolt in after the engine is in the cradle, I use these as “handles” for this side of the engine.
Waiting for a full set of Yamiya Engine Cover screws. They should be here in the next few days. I want them in the cam cover, before engine goes in. Polished two more tappet covers, four to go. They are a pain!
