Author Topic: 1976 Honda cb750K  (Read 26027 times)
Re: 1976 Honda cb750K
« Reply #75 on: November 22, 2023, 04:51:04 PM »
I clean and paint the undersides of fenders here to help hold off corrosion.
« Reply #76 on: November 22, 2023, 05:23:56 PM »
Me too. Let it dry thoroughly after a good scrub with a wire brush (in my cleaning tank)then seal it up with a couple of coats of Tremclad Silver Rust Paint. Nobody will ever see it but I like it to be finished. The front fender is a new one I had, so leaving it alone.
Offline BigAl
« Reply #77 on: November 22, 2023, 05:32:48 PM »
Wow, I'm impressed.  Great looking build!
1978 CB550K4
« Reply #78 on: November 22, 2023, 05:35:13 PM »
Thanks….. This is one of those rare bikes that was incredibly well preserved.
« Last Edit: November 27, 2023, 05:45:08 PM by BenelliSEI »
« Reply #79 on: November 22, 2023, 05:36:01 PM »
John
Get yourself some ACF-50 spray film coating for under that new fender.
https://learchem.com/products/acf-50.html
Offline richmagee7
« Reply #80 on: November 22, 2023, 06:18:21 PM »
Very nice build John.  I certainly agree with the Zen of wheel building.  I've only done one pair of wheels but it was very satisfying and gets an impatient person (me) to slow down and relax.  And yes, the first wheel took me at least 3 tries to get the lacing pattern correct.
« Reply #81 on: November 22, 2023, 07:17:23 PM »
John
Stu….. Never used it but will give it a try. Thanks.
« Reply #82 on: November 22, 2023, 07:20:37 PM »
I still have a rusty old pair of wheels sitting in the barn. If I get confused I can always lay them on the bench. It’s been a while since I needed them.
« Last Edit: November 27, 2023, 05:27:07 PM by BenelliSEI »
« Reply #83 on: November 22, 2023, 08:45:40 PM »
The bike looks very nice John. Always bugs me when the clutch cable is in front of the speedo!
Yeah, me, too!
For a [brief] while there were some (5cm?) shorter clutch cables out there that didn't do it so much, but they disappeared after a couple of years. Seems the clutch was harder to pull, probably because of the kink it caused at the cable adjuster by the lever.
A lower bar, no clutch cable in front of speedo.
I think the cable is 114cm long if I remember correctly
This bar a little bit wider too.
« Reply #84 on: November 22, 2023, 09:11:44 PM »
Yeah, me, too!
Which style bars are those Per ?
« Reply #85 on: November 22, 2023, 10:45:19 PM »
 I began to clean one that had so much road tar that I decided it was undercoated and left it as was.
« Reply #86 on: November 23, 2023, 12:37:10 AM »
Yeah, me, too!
Highway Hawk Fighter.
92cm wide.
I cut 5-6cm on each side. Do not remember exact. The brake MC with banjo to sit away from tacho.
« Reply #87 on: November 23, 2023, 01:33:13 AM »
Yeah, me, too!
92cm wide.
Those bars were quite long before you cut them;do they apply good leverage to your control of the bike? How do they feel with comfort during rides? The also look a little like Superbike bars.
« Reply #88 on: November 23, 2023, 02:10:28 AM »
Yeah, me, too!
92cm wide.
Really nice feel and handling.
Stock seat used
I had to add thin copper plate under the bar where seated to make the clamp better. (ca  0.5mm thick.)
Same I made for a dragbar dame bike had in the 80's.
« Reply #89 on: November 23, 2023, 03:01:48 AM »
Yeah, me, too!
92cm wide.
Stock seat used
Looking at the specs from Highway Hawk on their Fighter bars they are @ 3" rise and 3" pullback 36.5" wide(cut 5-6mm each side off= 80-82cm/30"-32" wide)
https://www.highwayhawk.com/highway-hawk-handlebar-fighter-920-mm-wide-90-mm-high-for-7/8-22-mm-clamping-chrome
4into1 in California has a similar bar to your cut width Per, at 32" wide, 3" rise, 3" pullback. They call them Street Bike bar.
I might go with them next, I bought their European bars which are 30" width, 2" rise, 4 1/4" pullback a year ago. They give a bit stiffer turn in handling than I like,  though are comfortable so I might get the Street bar over the winter. The extra 2" width might help with the turn in handling.
https://4into1.com/emgo-chrome-street-bike-handlebars-7-8/
« Last Edit: November 23, 2023, 04:56:31 AM by newday777 »
« Reply #90 on: November 23, 2023, 08:34:39 AM »
My throttle cables for the low bars ca 71-73 cm.
« Reply #91 on: November 23, 2023, 01:22:12 PM »
Nice stuff!
Happy Thanksgiving for those in US.
« Reply #92 on: November 27, 2023, 05:28:19 PM »
Winter arrived here today. Spent a few minutes in the shop and got the rear fender back on….. With a spotless wheel and fender, I’ll have to shine up the grab handle, turn signals and stalks next. One job leads to the next.
The centre stand looks cruddy with the frame polished up, so that will come off too…….. Oh well, +5 months until riding season, so may as well do it right. Still ordering parts, no lock tabs on the rear sprocket!
« Last Edit: November 28, 2023, 07:22:57 AM by BenelliSEI »
« Reply #93 on: November 28, 2023, 06:38:35 AM »
The never ending quest for completion!
The journey is where the fun is.
« Reply #94 on: November 28, 2023, 07:21:50 AM »
Good timing too…….. It snowed again this morning so 5 months before I need any motorcycles!  Rewired and finished up the tail light. The grab bar is in nice shape except for some slight fuzz around the turn signal brackets. Soaking in “Australian Terry Juice” overnight. The bike seems to have exploded apart today. I pull two bits off for every one that goes back on!
« Last Edit: November 28, 2023, 03:54:03 PM by BenelliSEI »
« Reply #95 on: November 30, 2023, 11:05:37 AM »
Back end is all back together. Waiting for some new lock tabs for the sprocket nuts. The side and centre stand look crappy so I’ll do them next. I’ll have to wait for my buddy Gary to show up for a shop day, before spinning the bike on the table. The front wheel needs to come off. It will need new spokes to match the rear!
Oil tank needs a good scrub and I need to find the “missing” hose! Will have to head off to  “Lash’s” place to pick up the motor too. Putting this off until my daughter comes out for a few days. My wife is walking without the cane (wearing an inflatable boot) but still don’t want to disappear for a full day…..
This bike came with a “fresh” 1974 K4 engine that I fitted to the 1974 Rickman CR. The replacement is CB750E-2563239.  Only +1000 numbers off my frame, so a very nice, coincidental fix!
« Last Edit: November 30, 2023, 11:35:12 AM by BenelliSEI »
Offline BigAl
« Reply #96 on: November 30, 2023, 06:37:55 PM »
My goodness that is a clean engine.  I would love to do the same to mine, but I think I'll be happy with mechanics and electrics performing for now.  Well done.
1978 CB550K4
« Reply #97 on: November 30, 2023, 08:18:26 PM »
A while back, “Lash” posted on here about his vapour blast cabinet he built himself. This engine started off with all the bits he put through it first. I have yet to see it, but I bet it is really spotless!
« Reply #98 on: December 01, 2023, 02:41:10 PM »
Did a bit more, late this afternoon. Side stand and centre stands get a coat of paint and shiny new springs, with a new pivot bolt.  Cheap $10 improvement that goes a long way.
      While searching for the ownership reminded myself this bike has a very nice NOS Honda seat, including an Owner’s Manual (repro) in the compartment. The PO spent some money on this thing…… I did transfer the ownership into my name, ages ago, so good to carry on.
Offline lash
« Reply #99 on: December 01, 2023, 04:35:30 PM »
Not sure where you got that engine number John. This one is 2452000 which puts it near the end of the Canada run. Last one shows as 2465992.
« Last Edit: December 01, 2023, 04:43:58 PM by lash »
