Author Topic: 1978 CB550 K4 Been sitting a while  (Read 10579 times)
Offline BigAl
« on: November 09, 2023, 07:00:11 PM »
Well, I got bored and found an old CB550.  Specifically a 1978 CB550 K4 with a little under 5,000 miles on it.  I think it has been sitting for maybe 30 years or so?  The gas tank was rusted paper thin and ended up in the trash.  Pity, I really wanted that tank, and a replacement is fairly pricy.  So I went with a cheap new tank in a shape that I never thought I would buy.  Instead of the nice teardrop shape I had envisioned, I bought something a bit more boxy.  It felt new and unusual for me.  The throttle would not turn due to the slide being seized in all four carbs.  Soaked them in acetone and they all slipped right out.  Took them all the way apart, soda blast, ultrasonic clean, new parts / screws / etc and I'm happy with them.  I took a stab at setting them up for pod filters, but after reading thread after thread of trouble with pods, I'm about ready to put the filter box back on and run the side panels instead of jamming all the electronics and battery under the seat.
The clutch was seized up, but new plates seemed to have done the trick.  Although it feels a little bit tight (as in it takes a little more force than I think it should with the clutch engaged).  I haven't tried to adjust it yet.
Currently, taken apart and sitting on my bench, is the master cylinder.  In the reservoir was what felt and looked like brown jelly.  So, I took it all apart, cleaned it up, brushed it out, and I think it is useable with a repair kit.  The bore is smooth but for the tiniest of a ghost of a mark where the plunger sat for 30 years.
So here is my question.  I can buy a new MC for $60.  I can buy a repair kit for $60.  The price points don't make sense.  Is there a compelling reason to not just buy a new MC?  I will admit, I am the type of guy who has a bit of nostalgia for the original equipment, but it doesn't make sense to me that the reaper kit and new are the same price.
I'll see if I can't post some pics.
1978 CB550K4
Online BenelliSEI
Re: 1978 CB550 K4 Been sitting a while
« Reply #1 on: November 09, 2023, 09:30:22 PM »
Good choice, my 1978 550K was one of my favourites! I’ve used a replacement master on my cb750K1. Initially, I installed it mid summer, to keep riding while I rebuilt the original. It works well, and I still have not rebuilt the original……
« Last Edit: November 09, 2023, 09:34:02 PM by BenelliSEI »
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #2 on: November 09, 2023, 09:40:13 PM »
All depends on what you what out of your bike.
if you want more of a resto, rebuild but it would be nice to get another to ride on and rebuild later.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #3 on: November 09, 2023, 11:13:26 PM »
I haven't used an aftermarket master cylinder yet, but hear they work OK.
Honda rebuild kit is $45 at South Sound Honda
https://www.southsoundhonda.com/--xpartsstream#/s/HOM//45530-404-315//1/y
Offline BigAl
« Reply #4 on: November 11, 2023, 09:19:46 AM »
Thanks newday777, that is a parts site I had not yet run across.
I have some POR tank coat coming in today.  Will get that done here this afternoon.  After that, there is no real reason why I couldn't start it up.
When I rebuilt the carbs I did set them up for a stab at pod filters, but am slowly changing my mind.  I'm not going to race the bike, just around town and the next town over.  In doing so I swapped for a bigger main jet, that is easily swapped back out, but I also raised the needles by 1 notch.  I do plan to replace the exhaust with a 4 into 1, the stock is old and rusty.  Maybe I can readjust the needle clips without deracking?  Can I scoot the linkage over enough to get at those 2 screws that hold the needle in?  Maybe it will be OK with the needle raised 1 with the more open exhaust running the stock airbox?
One more post after this one and I can start to put some pics up.  I take a lot of pictures....
1978 CB550K4
Offline carnivorous chicken
« Reply #5 on: November 11, 2023, 02:08:49 PM »
I used to rebuild MCs as a matter of course, but I've bought two David Silver Spares MCs -- one fore a 350F, one for a 550K -- and they have worked great. Downside is they look new compared to the rest of the bar switch housings, but you also don't have to risk rebuilding an MC and finding out it is damaged and/or still leakes, and then there's that damn clip you've got to fish out with a dental pick, usually corroded, sometimes broken off...
Offline BigAl
« Reply #6 on: November 12, 2023, 04:01:33 AM »
LOL, calj737, you are not wrong.  If I can't beat it out with a hammer I feel a bit lost...  I will give it a go with swapping the main jets back to stock and see how it runs.  I took a look at your build thread, very nice.  I initially envisioned a rebuild as thorough as the one you documented, but the more I get into mine, the more I realize that maybe this build should be my "learning curve" build and the next one can satisfy my desire for custom perfection (whatever that means).
Carnivorous chicken, yeah, that clip didn't want to come out.  I found that cussing loudly helped, and the blood let by the pointy tools I was using acted as a lubricant (and maybe a sacrifice to some motorcycle God).  The bore is pretty darn clean on the master cylinder, so I think I will rebuild it.  What you speak to is exactly what I am afraid of; a brand new mc amidst the patina of everything else.
Tank will coat today and I will let it cure for a few days after.  But, I should technically be in a position to fire the darn thing up next weekend.  To be honest, there is no real need to start it up.  It's cold here now, riding season is over, and I have quite a bit of work to do in order to have it ride ready anyway.  So why introduce fuel into a bike I'm still working on?  Well, because I'm not the sharpest tool in the shed I suppose, and I just can't help myself.
1978 CB550K4
Offline BigAl
« Reply #7 on: November 12, 2023, 05:37:33 AM »
Time to post a few pics, here is one on the way home from purchase.  Maybe, I can figure out how to attach a photo.....
1978 CB550K4
Offline BigAl
« Reply #8 on: November 12, 2023, 06:34:45 AM »
The carbs were pretty dirty and the slides were all stuck.
1978 CB550K4
Offline BigAl
« Reply #9 on: November 12, 2023, 06:35:51 AM »
More shots of dirty carbs
1978 CB550K4
Offline BigAl
« Reply #10 on: November 12, 2023, 06:39:57 AM »
Made the mistake of trying to put the staked screws back in and twisted one of the heads off.  Drilled it out, somehow without fouling the threads, and went back with hex head screws (with a little dab of blue locktite).  I know that the blue locktite will not prevent the screws from being removed because I took the whole thing back apart like three times.  The third and final time was because I forgot that little nylon washer in between the slide linkage and the carb body on #2 (on the common throttle shaft).  I managed to get that little washer where it belonged the first two times I put them all back together.
1978 CB550K4
Offline BigAl
« Reply #11 on: November 12, 2023, 06:42:19 AM »
Everything back in new including the pilot jet.  I wonder why they decided to press fit these later year carbs.
By the way, I would put this all in one post, but if I try to post more than one picture at a time it fails (probably user error on my part).  So one by one I guess.
1978 CB550K4
Offline BigAl
« Reply #12 on: November 12, 2023, 06:43:29 AM »
Back together.  Happy with the results.
1978 CB550K4
Offline BigAl
« Reply #13 on: November 13, 2023, 06:31:09 AM »
Tank coating this morning.  96 hours of cure time.  So maybe next weekend for first fire.
1978 CB550K4
Online Stev-o
« Reply #14 on: November 13, 2023, 09:15:13 AM »
Congrats on getting a 550...had one just like it a few years back.
Offline BigAl
« Reply #15 on: November 13, 2023, 12:42:51 PM »
Thanks Stev-o, enjoying it so far.  I'll let the fuel tank coating cure all week long, it's a little bit tough to dump the excess out but I did the best I could.  Moved on to the master cylinder, it seemed to clean up really well.  I couldn't help but run it through the ultrasonic.  Dried it out really well afterwards.
1978 CB550K4
Offline BigAl
« Reply #16 on: November 13, 2023, 12:46:04 PM »
Moving on to the caliper, believe it or not the piston is stuck.  I put 120psi on it through the brake line fitting with the compressor and nothing.  Maybe soak it in acetone?  It worked for the carb slides....
1978 CB550K4
Online Stev-o
« Reply #17 on: November 13, 2023, 02:07:47 PM »
Not surprised!  If you had a good master cylinder you could most likely use hydraulic pressure to get it out.
I may have a spare if you are looking for one.
Online BenelliSEI
« Reply #18 on: November 13, 2023, 02:26:47 PM »
Grease gun. Gently start a std grease fitting into the hard line hole. 1/2 a turn is enough, don’t strip the threads! Close the bleed screw and pump. It will come right out. For less mess, see next paragraph.
I took one of the original furl nuts off an old metal feed pipe and tapped it to take a grease fitting. Great tool, you generate 10 X the pressure of air and it walks out gently.
Next time you’re faced with stuck slides, just drop the carb in boiling water. Two minutes and the goo warms up and they slip out.
« Last Edit: November 13, 2023, 02:31:24 PM by BenelliSEI »
Offline BigAl
« Reply #19 on: November 13, 2023, 03:43:27 PM »
BenelliSEI, that's a good idea, the thought never crossed my mind.  I dumped it into my old faithful paint can full of acetone.  It usually unsticks stuff that's stuck fairly well.  If that doesn't work, then grease gun it is.
1978 CB550K4
Offline BigAl
« Reply #20 on: November 14, 2023, 07:29:19 PM »
Finally got the piston out of the caliper.  Doused it in penetrating oil for a while and let it soak.  Gave the piston a few calculated whacks with a hammer, and then applied some compressed air.  That did the trick (I had the grease gun ready in the wings).  I cleaned it up with some dawn dish soap and a brass wire brush and then ran it all through the ultrasonic.  Turned out fairly well, I think it's clean enough and smooth enough to use.  So I think I will order out a new piston, rubber o ring, and bleeder screw.  Probably one new caliper bolt as well (one of the two was covered in a white dusty something, the other was clean as a whistle).
I'm also tempted to order out new break lines, the whole kit with washers, banjo bolts, etc.  The pressure switch fitting looked good, the pressure switch itself has some crud in it but may still be good.  I suppose I can apply some pressure and check continuity with my voltmeter.  If they are cheap I may add one to the order.  We shall see.
1978 CB550K4
Offline BigAl
« Reply #21 on: November 14, 2023, 07:41:38 PM »
I've been thinking about handle bars.  Initially I wanted to go with clip ons (no real idea how they install), but have been leaning toward clubmans (installation seems fairly self evident).  In reading through threads on the forum, a lot of folks say there is no need to adjust break lines / clutch cable / throttle cable to move to clubmans.  I guess I should figure that out before I drop bike funds on new break lines.
1978 CB550K4
Online BenelliSEI
« Reply #22 on: November 14, 2023, 08:50:54 PM »
Find a sharp tool (I use a dental pick with a ninety degree bend in the end) and really scrape out the seal groove. Particularly the inside, back corner you can’t see. The crust that builds up in there is hard to get out. If that groove is not spotless the seal will not sit back far enough. Your new piston will not slide in effortlessly and your brakes will “drag” and squeal.
Online Stev-o
« Reply #23 on: November 15, 2023, 06:27:23 AM »
Norma nHyde “M” bars are very popular as a particular model. These bars are the style of modern “Hooligan” type bikes. Very sporty, comfy, and no changes to cabling required.
I have the M bars on my 550, like them very much.  I hate the clubmans on my 750, very uncomfortable riding position, but need them as it's a "racer" type bike with a fairing.
Offline BigAl
« Reply #24 on: November 15, 2023, 04:35:41 PM »
BenelliSEI, great minds think alike...  The caliper cleaned up well.
I checked out the M bars, I do like them.  It's interesting how my thoughts on the bike have changed over time.  I initially wanted a sexy, sleek, most likely impractical, full on cafe racer.  Stripped down, pod filters, clip-ons, upgrades all around to suspension / brakes / etc.  Beautiful bikes those are.  The more I dig into it the more I realize that what I am gravitating towards is something more sporty than the original 78 CB550K, but not something as sleek as originally envisioned.  The M bars fit this new way of thinking about the finished product.  I am going to leave the stock airbox.  It will have a new tank, and a new seat, 4 into 1 exhaust (although I don't mind the looks of a set of 2 into 1's but those seem harder to come across) and I want it to be mechanically on point.
1978 CB550K4
