Author Topic: Another project-1976 Honda CB550K  (Read 55145 times)
Offline Mark1976
Re: Another project-1976 Honda CB550K
« Reply #375 on: April 16, 2024, 10:36:04 AM »
   Food for thought, you can lay you base coat (let it sufficiently flash) then color (let it flash) & clear coat in one process one after the other or you can shoot your base and let it dry (cure) and then wet sand it back and do your candy color coat and finish with your clear top coat. My experience with candy colors is always the layering of each specific coat (base, color, clear) and sanding it back (2000 grit) lightly before doing the next, improves the perception of depth within the finish and improves the overall quality of the finish. It takes longer but it also helps in dealing with any problems that arise. Patience is your friend in this area, especially if your inexperienced. Just a thought.
Start with the end in mind...
Offline denward17
« Reply #376 on: April 16, 2024, 12:13:25 PM »
Thanks for the tips Mark, much appreciated.
66autocolor recommended that I use Transtar 4613 (black 2in1 primer) as the base for the color coat, so I have that ordered and it should get here tomorrow.
Like your thoughts on lightly scuffing after the base, color coat.
I have decals to go on so what I had planned was:
2-3 more coats of the Transtar black primer, scuff.
3-4 coats of color, let dry overnight, then scuff.
Apply 2 coats of 1K clear, let dry for about 2 days, then scuff.
Apply decals, let dry for a week, then apply 2-3 coats of 2K clear.
Offline Mark1976
« Reply #377 on: April 16, 2024, 06:48:07 PM »
   That sounds about right, the only thing I might add is appropriate coverage and dry/cure time.  If it looks good at 4 coats, let it go, more is not better, it's a black base coat. Its only gonna get so dark. Normally 24hrs is sufficient time to dry/cure, so that sounds right, it's what ever the mfgr recommends, I'm not familiar with the 1k, 2k products.
   When you go to wet sand between base, color and clear coat don't use a new sheet of paper, use one that has been used a little bit. New paper is a little sharper/less flexible and can/will take off more surface color than you'd imagine (think sand thru). Remember your just scuffing the surface, to improve adhesion and surface continuity (dust that sometimes embeds in the surface), so go lightly. Use a little soap (a couple of drops) to your bucket of water, helps keep the paper clean. Cleanliness is your top priority, wipe it down good clean and dry between every process, especially before applying clear coat. Check your time between coats, again what ever the mfgr suggests, it'll minimizes problems like runs, and reactivity between coats and improves surface finish. I normally start with the underside of the tank, get used to whatever spray pattern and paint texture your working with under there.
   Then check your weather, look for a 2 day window of good consistent weather, 1 day for color, 1 for clear. Done.
   A week in between is good, check with whom ever is supplying your graphics about applying clearcoat over them, never hurts to ask. I normally sand right before applying clear over graphics. But that's me. Shoot your 2 coats of clear and see what you get.... Personally, at this point, once it dries 24hrs later, I'd sand it all back with 4 or 5000 grit and apply another 2 light coats. These are the coats that give you the margin of coverage to sand and rub out for your final finish, but that's up to you...
My apologies for the long winded rant, painting's not cheap anymore, so getting it done right the first time is the best advice I have. Good luck...
Offline denward17
« Reply #378 on: April 22, 2024, 08:58:36 AM »
Placed decals on tank this morning, had a couple of small boo boos, but I straighten them out the best I could with a little heat.
They are not perfect from side to side, but close enough that I'm not gong to take them off and redo.
How long do I need to leave the decals to dry before I try to tape over them?
Plan now is to use Fine line tape on top of the decal on the inside so I can paint the cleats black, then clear coat all of it.
Offline newday777
« Reply #379 on: April 22, 2024, 10:51:03 AM »
7 days on the decals to fully dry.
Stu
My current rides
Prior bikes....
Offline denward17
« Reply #380 on: April 25, 2024, 09:09:21 AM »
I ended up waiting 3 days for the decals to dry, thought that was enough.
I used Fine Line tape to tape on top of decal so I could paint the cleats black.  Did that this morning, waited 30 minutes and peeled off the tape.
Gave it another 45 minutes, cleaned off tank with alcohol, Spray Way window cleaner on the decals, and started spraying clear.
3 coats of clear on side covers, 4 coats on the tank, looks good to me.
Will lightly wet sand with 2000 grit in a few days and buff.
And No, it is not perfect, but good enough for me, not building a concurs level bike.
« Last Edit: April 25, 2024, 09:11:34 AM by denward17 »
Offline Mark1976
« Reply #381 on: April 25, 2024, 09:16:21 AM »
Looks pretty good from here, nice and easy on the final sand and it'll look like brand new once you rub it out. Got any white compound.
Offline grcamna2
« Reply #382 on: April 25, 2024, 10:05:27 AM »
Denny,those parts are looking very good  :) What color/brand paint?
I like the shade of green on the tank,plus the center black w/ stripes.
I'd like to see it in the sunlight.  8)
75' CB400F/'bunch o' parts'
Offline denward17
« Reply #383 on: April 25, 2024, 10:58:15 AM »
Bill, here is the color I chose from 66auto:
It's a 1K paint that came in a SprayMax can, good nozzle.  House of Kolor candy paint.  Took 3 cans for tank and side covers.  Base had to be black before I sprayed the color.
https://www.66autocolor.com/products/house-of-kolor-k462-bermuda-triangle
Decals came from:
https://cbdecals.afegraphics.com/view_product.php?adminshopping=&product=76cb550k-TNKT-CB00240
The black I had some left over VHT Roll Bar and Chassis paint, High Gloss.
The clear is Spray Max 2K Glamour.
I'll get a pic in the sun tomorrow when I feel comfortable touching it.
Offline grcamna2
« Reply #384 on: April 25, 2024, 11:13:31 AM »
Decals came from:
I like it.  thanks for the info Den.
Have you painted automobiles in the past ?
Offline denward17
« Reply #385 on: April 25, 2024, 11:38:22 AM »
^No sir, but have dabbled for a long time.  Did a lot of research and reading.
Offline BenelliSEI
  • 1969 cb750
« Reply #386 on: April 25, 2024, 04:21:23 PM »
 I’ve never tackled that level of paint and a truly impressed!
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #387 on: April 25, 2024, 05:30:29 PM »
Those look great!  Good Job!
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #388 on: April 26, 2024, 07:00:47 AM »
+1...great job!
Offline denward17
« Reply #389 on: April 26, 2024, 07:38:37 AM »
Thanks Guys,
Bill, out door picture before wet sanding....
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #390 on: April 26, 2024, 08:02:45 AM »
Good progress!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline grcamna2
« Reply #391 on: April 26, 2024, 10:49:54 AM »
Thanks Guys,
Oh,that's very Nice  :) ;)
I like that color And the mix of metallic sparkles.
« Last Edit: April 26, 2024, 01:32:36 PM by grcamna2 »
Offline denward17
« Reply #392 on: April 26, 2024, 01:15:35 PM »
Buffed out and sporting trim.....
Offline grcamna2
« Reply #393 on: April 26, 2024, 01:30:28 PM »
Yeah !   :o :) 8) 8) 8)  They really 'POP' in the sunlight.
I hope this 550 is your 'Keeper' and you put Lots of miles on this bike,showing it off  ;)
Offline denward17
« Reply #394 on: April 26, 2024, 04:06:06 PM »
Thanks.  No long term plans have been decided yet.  I need to schedule an appointment with DMV to get it inspected before they will register it and give me a tag.  I hope to do that in about 2 weeks.  Everything is pretty much ready, still working on cleaning inside of tank, got it soaking with Evaporust now.  Inside of tank is not to bad, so that won't take but a few days.
Last couple of days I've been thinking about painting the 750 since this one turned out well.  I may do that next fall.
« Reply #395 on: April 27, 2024, 01:34:47 AM »
Very very nice work denward...gonna be gorgeous all assembled, let it cure and garden a bit, don't want to rush it at this point. You do know about the fuller neck needed a epoxy sealing edge to keep the fuel from working under the pain job and wrecking it don't you?
The neck needs a band unpainted and then sealed with an epoxy that is fuel proof like JB Weld to prevent fuel vapor and condensate from wicking it's way under the paint at the neck and ruining your paint job.
Offline denward17
« Reply #396 on: April 27, 2024, 03:04:52 AM »
I have read about that and did leave about 1/4" or so of the top of the neck unpainted.
Hmmm, might be a good idea to add that now.
Assume I just put the epoxy on top of the paint line and not on the gasket surface of the neck?
Offline newday777
« Reply #397 on: April 27, 2024, 05:36:13 AM »
This is how Honda did the filler
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #398 on: April 27, 2024, 05:47:21 AM »
Shoot a picture of the side of that neck please.
I'm not at the shop until tomorrow
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #399 on: April 27, 2024, 05:48:06 AM »
The paint goes all the way to the top of the neck
Stu
My current rides
Prior bikes....
