Author Topic: Another project-1976 Honda CB550K  (Read 45952 times)
Online Mark1976
Re: Another project-1976 Honda CB550K
« Reply #300 on: March 13, 2024, 04:10:26 PM »
   Coming together, looks great!!!
Start with the end in mind...
« Reply #301 on: March 13, 2024, 04:27:42 PM »
Well done Dennis. Looking great!
Offline denward17
« Reply #302 on: March 14, 2024, 01:09:02 PM »
Re-torqued head and installed camshaft, appears to be timed correctly.
Blue Loctite on camshaft sprocket bolts.
1-4 at TDC, with centerline cutout of cam shaft lined up to top of head.
Online Mark1976
« Reply #303 on: March 14, 2024, 08:02:33 PM »
Coming along well....
Offline denward17
« Reply #304 on: March 15, 2024, 03:20:59 PM »
Valve cover installed today, valve adjustment complete.
Waiting for o-rings for end caps, hopefully install engine next week.
« Reply #305 on: March 15, 2024, 03:54:16 PM »
Nice progress!
Offline denward17
« Reply #306 on: March 17, 2024, 10:19:25 AM »
Honda badges stripped and re-painted with Testors model enamel paint, and a syringe.
After the white dries, will go around the letters with a Q-tip and acetone to clean up.
Offline denward17
« Reply #307 on: March 17, 2024, 10:20:35 AM »
Hopefully tomorrow afternoon......the engine goes in...
« Reply #308 on: March 17, 2024, 10:40:06 AM »
Dennis….. I like your style!
Offline Little_Phil
« Reply #309 on: March 17, 2024, 11:53:42 AM »
Looking good, that's a tricky job.
« Reply #310 on: March 17, 2024, 12:12:40 PM »
Very tedious job;labor of love.
Offline denward17
« Reply #311 on: March 19, 2024, 03:21:30 PM »
Made some progress the last couple of days....
Engine in, carbs were cleaned and put together earlier but I bench tested today with gas, no leaks.
Installed oil filter, carbs and air box with new air filter.  Still have 4 in to 1 Delkevic to install, along with brake pedal and breather system hoses, all cables and etc.
I just ordered a battery so will be about a week before it arrives.
« Reply #312 on: March 19, 2024, 03:33:21 PM »
Dennis….. moving along and it looks great!
Online Mark1976
« Reply #313 on: March 19, 2024, 04:13:23 PM »
Clean as a whistle, looks great!!!
Offline Little_Phil
« Reply #314 on: March 21, 2024, 10:59:58 AM »
I ordered a battery in January over here in the UK for a 550 about 6.30 in the evening from a supplier over 200 miles away. I was stunned when it arrived here before 11:30 in the morning the next day.
Offline denward17
« Reply #315 on: March 21, 2024, 02:21:16 PM »
Installed chain, chain guard, electric panel (with all connections), left side transmission cover, gear shift, rear brake arm, and finally rear brake pedal.
Wired and installed electronic ignition.
Waiting on battery and a couple of emissions hoses for air box and plenum.
Still to do:
Clean out gas tank and install new filter screen/seal on petcock.
Install kickstart arm.
Install emission hoses to air box.
Install battery box and battery.
Install clutch, gas cables.
Install oil.
The big one is deciding what paint color to use for tank and side covers........
Hopefully can start next week with auxiliary tank.
« Last Edit: March 21, 2024, 02:26:39 PM by denward17 »
« Reply #316 on: March 21, 2024, 04:54:13 PM »
Looking very tidy!
Online Mark1976
« Reply #317 on: March 21, 2024, 07:23:32 PM »
Patience is your friend, looks pretty damn good.
« Reply #318 on: March 21, 2024, 07:37:34 PM »
The frame and swing arm look very good;which brand/type paint did you use Dennis ?  8)
Offline denward17
« Reply #319 on: March 22, 2024, 04:41:02 AM »
Thanks, It was VHT Epoxy first coat, and then 2 coats of VHT Roll Bar and Chassis paint.
« Reply #320 on: March 22, 2024, 08:47:39 AM »
That's a good,hard base and the roll bar/chassis paint should hold-up under lot's of stress through the years;better than original.
Offline alexZan
« Reply #321 on: March 23, 2024, 09:30:33 AM »
Hey guys, quick question...The headlight on my '77 cb550k isnt working. Im reading only 6volts at the bullet connectors terminating at the headlight. Any ideas why I am not getting 12?
Thanks in advance!
Offline denward17
« Reply #322 on: March 23, 2024, 09:49:27 AM »
Thanks in advance!
Probably best to ask your question here:  http://forums.sohc4.net/index.php/board,2.0.html
Welcome to the forum!
Offline denward17
« Reply #323 on: March 24, 2024, 07:59:23 AM »
Little more progress made.....hopefully will get battery in the mail within the next couple of days.
Delkevic installed, those springs are a pass in the a$$.
I ended up stretching them some before install, that helped a lot.  I struggled with them for about 15-20 mins before realizing I didn't have enough strength to put them on as they were.
« Reply #324 on: March 24, 2024, 10:29:33 AM »
Dennis….. looking great. If you’re missing a wrench, it’s in there behind the brake pedal switch!
