Author Topic: Another project-1976 Honda CB550K  (Read 17408 times)
Re: Another project-1976 Honda CB550K
« Reply #475 on: July 16, 2024, 08:41:35 AM »
I have enjoyed almost 400 miles of riding since put together, bike is running great and pulls good in upper RPM range, with exception to low speed hesitation/gurgle.
I was able to find 4 sets of needle set jets at DR. Powersports in Iowa (Thanks to Dex at Sound Sound Honda), got them ordered.
Want to compare the original Honda needle to whatever I have, updates to follow when I receive them and have time to tear carbs apart .... again.
I like to measure the needle jet/nozzles(compared to new ones)using my 'pin gauge set' to determine how much they've worn from the needles sliding through there so much.
I called and spoke with Dex on other parts just Friday;I enjoy how helpful they are there at South Sound Honda,especially locating NOS Honda parts at other dealers across the country.
He even gave me a choice of a dealer up in Norwich,ONT on the part I was searching for.  8) ;)
Online newday777
« Reply #476 on: July 16, 2024, 08:45:02 AM »
Dexter is good at finding missing parts in the NLA listing's.
Offline denward17
« Reply #477 on: July 16, 2024, 08:55:41 AM »
He sure is, this is the 3rd time he helped me find a Honda part at a different dealer.
« Reply #478 on: July 16, 2024, 10:33:42 AM »
That Norwich, Ont. dealer is where I found my exhaust clamp!
« Reply #479 on: July 16, 2024, 11:16:37 AM »
Davidson's ?  :)
« Reply #480 on: July 17, 2024, 04:53:34 AM »
Davidson's ?  :)
Yup. Speak to “Toby” in Parts Dept. Very helpful!
« Reply #481 on: July 17, 2024, 04:55:39 AM »
Denis….. leave it alone for now and ride it. Winter will come soon enough!
Offline denward17
« Reply #482 on: July 20, 2024, 11:18:41 AM »
Couldn't resist John, Since I got the new needles I decided to take carbs off the bike and install the new Honda jet needle set.
I only have 1 carb needle out so I could inspect.
Old needle I suspect is a Keyster part? D26
New needle has part # 272304 on it.
Just for grins I tried to measure with calipers:
Length:
D26 = 55.55mm
272304 = 55.85mm
Tip diameter:
D26 = 1.39mm
272304 = 1.41mm
This explains why it is a tad rich down low speed operation.
Now what do I do about the clip position?  As it came apart, it was in the 4th position from top, don't know if this is where Honda intended or not, I cannot find a reference.
« Reply #483 on: July 20, 2024, 01:06:48 PM »
Length:
D26 = 55.55mm
272304 = 55.85mm
Tip diameter:
D26 = 1.39mm
272304 = 1.41mm
Denis,did you get OEM Honda 'needle sets' which include the needle jets/nozzles along with the new needles?  They do come as a set.
Offline denward17
« Reply #484 on: July 20, 2024, 01:56:09 PM »
Length:
D26 = 55.55mm
272304 = 55.85mm
Tip diameter:
D26 = 1.39mm
272304 = 1.41mm
yes sir, plan is to change them as well.  I picked up a set of original emulsion tubes from another member and had those installed already, but decided to just go ahead and replace them as a new set.  The needle is the only non-original part, with exception to JetRus main jets.
« Reply #485 on: July 20, 2024, 02:54:36 PM »
The emulsion tubes which have a number of holes through them and thread into the lower carb. body and the main jet connects to on the bottom doesn't see much wear.
The needle and needle jet(set)will wear together,which messes with how the fuel atomizes.
I have searched for stock NOS Honda 'needle sets' for other bikes and found they can be difficult to locate. I like the performance of the bike after I've replaced them.  ;)
Offline denward17
« Reply #486 on: July 20, 2024, 03:35:48 PM »
Here is a pic of the needle jet set with the emulsion tube that presses in, the main jet presses in just underneath and uses an o-ring to help hold the jet in place.  Then the "wing" goes on over the main jet and presses within the float bowl to hold it in.
« Reply #487 on: July 20, 2024, 03:58:53 PM »
OEM NOS Honda needle set  Excellent.
Offline denward17
« Reply #488 on: July 22, 2024, 02:15:00 PM »
Honda needle jet sets are installed, new needle set at position #3, moved up from 4th position.
Let sit in the bench vice for a couple of hours with fuel applied to make sure I had no leaks from bowl gaskets, no issues.
Installed carbs, air box and battery box.
Wednesday will install carb cables, battery and sync balance carbs and give it a whirl and see what happens.
« Reply #489 on: July 22, 2024, 02:20:00 PM »
Oh, I can imagine that bike will run Great.  :)
Which gasoline do you run,Ethanol-Free?
The Ca. gasoline is only available with ethanol and it doesn't give much power and goes stale very fast..
Offline denward17
« Reply #490 on: July 22, 2024, 03:01:56 PM »
yes ethanol free and 89 octane if I recall..........
« Reply #491 on: July 22, 2024, 06:53:27 PM »
Just what you need  ;)
Offline denward17
« Reply #492 on: July 24, 2024, 09:13:28 AM »
Successful carb syncing today after jet needle set installed...............idles well and takes throttle blip good.
Rain is all over the place in my area so might not get a chance to ride today.
« Reply #493 on: July 24, 2024, 11:02:15 AM »
I know you didn't ask for the rain;we certainly need some out here after almost a month of 100+ degree heat Waves !!
I'm glad to hear you've installed the new emulsion tubes/needle sets  :)
Many sets of carbs 'from back in the day' are running around 'in need' of them;you will feel the difference  ;)
Offline denward17
« Reply #494 on: July 24, 2024, 11:47:26 AM »
Looks like the rain is going to hold off until later this evening, so was able to go on ~24 mile ride.
Bike is running fantastic!  The low speed gurgle is gone, when I turn into a low speed corner in 2nd gear and slowly increase throttle it is crisp now, no hesitation.
To recap:
I had Keyster D26 needles in the 4th slot, they were removed  and I installed the Honda needles (272304), with the clip in the 3rd (center) position.
These are the 087A carbs.
With old needles I tried to compensate with the air mixture screws and went up to about 2 3/4 turns out, it helped but gurgle was still there.  With new needles I am 1 1/2 turns out.
« Last Edit: July 24, 2024, 11:51:46 AM by denward17 »
Online newday777
« Reply #495 on: July 24, 2024, 11:52:12 AM »
To recap:
I need to do them in my K5..... same gurgling rolling back on slow after letting off even just a little bit
Offline Mark1976
« Reply #496 on: July 24, 2024, 12:09:24 PM »
To recap:
Congrats,  well done...
It's a process...
Start with the end in mind...
« Reply #497 on: July 24, 2024, 01:27:03 PM »
Well done Denis. Nothing feels better than solving a problem like that!
« Reply #498 on: July 24, 2024, 02:02:26 PM »
To recap:
Smooth power delivery  ;)
Offline denward17
« Reply #499 on: July 24, 2024, 03:09:44 PM »
Thanks Guys, discovered an oil leak after my ride today.
The gear shaft seal, which was replaced by a Honda seal back when I was cleaning and rebuilding the top end.
I discovered today while searching there appears to be 2 different sizes from Honda 13.8mm x 24mm x 5mm and 14mm x 24mm x 5mm.
I ordered both to see which one will fit better, not sure what's going on here but will update after seals arrive.
