Author Topic: Identify this Fuse Box?  (Read 1241 times)
« on: November 13, 2023, 07:00:49 AM »
This came with a stack of other NOS stuff I bought. I don’t think it’s SOHC cb750. Usual three fuses with cover markings; 15A Main, 7A Headlight, 7A Taillight. Two spare fuses in the cover. Note: the white connector uses 6 Female ends. Anyone recognize it? Need it?
Offline Erny
Re: Identify this Fuse Box?
« Reply #1 on: November 13, 2023, 07:03:39 AM »
Maybe for 500/550?
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
« Reply #2 on: November 13, 2023, 08:13:59 AM »
« Last Edit: November 13, 2023, 08:19:53 AM by Don R »
« Reply #3 on: November 13, 2023, 08:21:52 AM »
My CB750 K6 fuse box look like that one.
BUT, mine should have male connectors. Quick search finding K6.
https://www.cmsnl.com/honda-cb750k6-four-england_model14383/box-assyfuse_32110341702/
« Last Edit: November 13, 2023, 08:25:27 AM by PeWe »
Offline CycleRanger
  • No comment about being an
« Reply #4 on: November 13, 2023, 08:54:04 AM »
Maybe for 500/550?
I think you're right, 550. The plastic cover with the spare fuses is often lost or broken.
« Reply #5 on: November 13, 2023, 09:17:11 AM »
Maybe for 500/550?
My '76 550F has 5 fuses...maybe it's for an early 500?
Offline CycleRanger
« Reply #6 on: November 13, 2023, 09:48:01 AM »
Maybe for 500/550?
My '74 550 had a fuse box like this one.
« Last Edit: November 13, 2023, 11:13:55 AM by CycleRanger »
Online bryanj
« Reply #7 on: November 13, 2023, 10:40:30 AM »
500's only had 1 fuse
Offline Erny
« Reply #8 on: November 13, 2023, 10:43:04 AM »
Maybe for 500/550?
My 550K1 has 3, like here
« Reply #9 on: November 13, 2023, 10:59:24 AM »
  I'm thinking newer 750's had that. 77/78?
  https://www.partzilla.com/catalog/honda/motorcycle/1977/cb750k-a-750-four-k/battery-regulator
Don…… the one in your link shows male pins in the connector. One I have is opposite. My K7 and K8 have 5 fuses…..
« Reply #10 on: November 13, 2023, 11:00:30 AM »
Maybe for 500/550?
Does your connector look like this one (with female pins inside)?
« Reply #11 on: November 13, 2023, 11:06:57 AM »
Searched early cb550 and may have found it!
Offline Erny
« Reply #12 on: November 13, 2023, 11:07:01 AM »
Not sure. Have not seen it long time...
Offline Erny
« Reply #13 on: November 13, 2023, 11:07:50 AM »
Search early cb550 and may have found it!
  • I'm back
« Reply #14 on: November 13, 2023, 01:12:12 PM »
Nope. The correct cover fusebox for the CB550K-K2 and the CB500K2 GENERAL EXPORT is shown here: https://www.cmsnl.com/honda-cb500k2-general-export_model50441/cover-fuse-box_32117341702/
Note the hole to accomodate the grommet for three spare fuses and on the outside it says 5A for TAILLIGHT and not 7A. See pics.
« Reply #15 on: November 13, 2023, 01:36:57 PM »
Well…..If any one needs it, I certainly don’t. Keep guessing!
« Reply #16 on: November 13, 2023, 07:05:34 PM »
In 2008 I made 2 fuseblocks for a rider in Alberta who ordered them for his 2 CB550 bikes. So, I made two of my ATC fuseholders with Blades connectors and sent them to him. I got them back about 2 weeks later because both of his 550s required fuseholders with Receptacles, instead. After that, I started asking each person who wanted a 550 fuseblock whether their version needed BLADES or RECEPTACLES in the connector, because the 550 uses both. I haven't yet figured out where the delineation is, whether it is a year model or the F versus K model, or what, but I know for sure that 550s use both types of connectors.
« Reply #17 on: November 13, 2023, 08:33:42 PM »
Well that explains a lot and matches the listing too. Early cb750F and last two years of 550K.  I’ve had a ‘75 cb750F and my first SOHC Honda was a ‘78 550K so it my have come with one of them…… Thanks. .
« Last Edit: November 13, 2023, 08:37:04 PM by BenelliSEI »
« Reply #18 on: November 14, 2023, 07:48:08 AM »
Moved it to “For Sale”. $30 donation to this Forum + Postage to my PayPal.
« Reply #19 on: November 14, 2023, 05:51:15 PM »
 My brother needed an electrical part for his K4, I snagged one off a parts bike and when I got there, we had the same problem, the plug had switched sides from one year to the next. I forget what the item was.
  One time his starter relay welded closed, he couldn't get neutral and finally laid the bike down in the grass until the battery went dead.
