Author Topic: Guess I'm Confused  (Read 741 times)
Offline Vintageguy
Guess I'm Confused
« on: November 15, 2023, 08:49:58 AM »
In an earlier thread I asked about the process involved in removal/replacement of the alternator-stator cover on my 1978 750F.  Just when I thought I had it, I began to question if there are screws INSIDE the cover that need removal for the process. Thought it was just a reducer gear, washer and dowel pin. Thank you for any and all responses.
Offline 69cb750
Re: Guess I'm Confused
« Reply #1 on: November 15, 2023, 08:56:05 AM »
The inner magnet screws are on outside.
The stator screws are on inside.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: November 15, 2023, 01:57:51 PM »
Loosen the three screws on the centre, before removing the cover. They don’t need to be removed to get the cover off but it’s so much easier with the cover secure to the engine!
« Last Edit: November 15, 2023, 03:05:40 PM by BenelliSEI »
Offline Bodi
« Reply #3 on: November 15, 2023, 02:44:24 PM »
What Benelli said. Plus, on reassembly, wrap some tape around the ends of the field magnet bobbin and screw it onto the cover loosely. Install the cover with a screw or two (locating it on the dowels) then tighten the coil screws. There's some play in those screws and the coil is a tight fit in the rotor. Take the cover off, remove the tape, and the rotor won't scrape on the coil.
