Author Topic: Broken Speedometer Stud  (Read 891 times)
Offline grumpy56
« on: November 17, 2023, 10:15:19 AM »
Any ideas on how to repair this or does the unit need to be disassembled? Speedometer works well. Thanks.
Offline jaytee-nz
Re: Broken Speedometer Stud
« Reply #1 on: November 17, 2023, 12:59:33 PM »
The studs are pressed in so you would need to disassemble the speedo to remove it. You could drill it out and replace it with a bolt but the reason the stud is pressed in is so you can tighten the nut without the stud spinning - could be a problem with a bolt though.
Offline Tim2005
« Reply #2 on: November 18, 2023, 02:35:01 AM »
It looks like there might be enough left there to get a threaded sleeve onto, which could be held in place by a good quality retainer like Loctite 648 or similar adhesive. You've nothing to lose by trying it.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: November 18, 2023, 06:19:54 AM »
Ouch, new bolt from inside with something holding it in place?
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #4 on: November 18, 2023, 07:43:21 AM »
Tack weld new bolt or threaded rod in place or use epoxy
« Reply #5 on: November 18, 2023, 09:56:24 AM »
Maybe cut it flush and drill and tap and screw in a new threaded insert with a little JB Weld to keep it from spinning if the pressed in collar is holding firm. How easy I wonder does that fitted piece come out. Maybe remover and exopy in another from a junk set of gauges. Just spitballin' here.
« Last Edit: November 18, 2023, 09:59:00 AM by ekpent »
Offline grumpy56
« Reply #6 on: November 20, 2023, 07:09:33 AM »
Was able to thread the nub, so will get a threaded sleeve and a short piece of 6mm threaded rod and see what happens.
Offline grumpy56
« Reply #7 on: December 03, 2023, 07:03:53 AM »
Used a 15 mm threaded sleeve with a short piece of 6mm barstock with a dab of red locktite on both sides and all is well.
