Author Topic: Oil Pump  (Read 1865 times)
Offline M_Stone76?
Oil Pump
« on: November 20, 2023, 04:41:04 PM »
Hello, not sure if this is the right fourm to ask this question
been doing some winter maintaince on my 76' K and decided to pull/rebuild the oil pump.
so far everything has gone great, the only concern i have is priming it. i know of the old trick packing the pump w vasaline to prevent cavitation and create a vacuum.
but what i don't know is what part of the pump i have to pack. so far ive packed every gallery except for the leak stopper valve.
too much?
when i am ready to put the pump back into the bike, do i still have to prime it with oil, submerged? or can i slap it back on full of Vaseline and hopefully the oil will push its way through.
thanks.
Offline BenelliSEI
  • 1969 cb750
Re: Oil Pump
« Reply #1 on: November 20, 2023, 05:36:53 PM »
Dip it in oil, install it, pull your plugs and spin it until your oil warning light goes out. It will be fine after that.
« Last Edit: November 21, 2023, 05:52:29 PM by BenelliSEI »
Re: Oil Pump
« Reply #2 on: November 20, 2023, 07:32:46 PM »
I submerge them in 20w50 oil to halfway up the pump body and spin the gear (in the same direction as the crankshaft runs) until the bubbles stop coming out of the ports. Then I pick up the thing, dribble oil across the floor to the engine, crawl under the engine so I can get the oil in my eyes, then bolt the pump in, still upright. Then I turn the engine upside down and install the oil pan and go wash my face.
...it's almost always like that...
Offline Floshenbarnical
  • Money pit enjoyer
Re: Oil Pump
« Reply #3 on: December 02, 2023, 09:51:00 AM »
This is my favorite post on the forum but can I send you a pair of goggles mate
"All things change in a dynamic environment. Your effort to remain what you are is what limits you."
'77 CB750 SS
Re: Oil Pump
« Reply #4 on: December 02, 2023, 07:44:40 PM »
Thanks for the offer, but they are too hard to clean oil off of. They're always so 'streaky' afterwards, ya know?  ;)
Offline Honda Hansel
  • Sherwood Park AB
Re: Oil Pump
« Reply #5 on: December 08, 2023, 07:09:05 AM »
Hi
Priming the oil
This is how I do all my priming of motor cycle and car engine
I use a oil accumulator
Mine happens to be a Moroso race style accumulator
Pressure it up with shop air and pump the oil in and that's is easy as taking candy from kid's
Honda Hansel
Honda Hansel
#1 1977 CB750 K7 #2 1981CX500C
#3 1982 CX500TC TURBO #4 2009 KAWASAKI KLX250
#5 2017 YAMAHA 1200 TENERE
#6 2020 KAWASAKI Z900 RS SE
#7 1978 HondaCB750F project bike
Offline newday777
Re: Oil Pump
« Reply #6 on: December 08, 2023, 08:56:12 AM »
You posted this somewhere else recently. 🤔
Stu
My current rides
Prior bikes....
  • Sherwood Park AB
Re: Oil Pump
« Reply #7 on: December 09, 2023, 06:36:20 AM »
Yes I did Stu
I posted it on my Resto thread
This works real good when engine oil pump is dry
when I read the Honda shop manual and figured out how the pump works
I will never start a dry engine
Honda Hansel
Honda Hansel
Offline newday777
Re: Oil Pump
« Reply #8 on: December 09, 2023, 07:56:52 AM »
Hi
Priming the oil
Honda Hansel
How do you get the oil into the accumulator?
Stu
My current rides
Prior bikes....
  • Sherwood Park AB
Re: Oil Pump
« Reply #9 on: December 09, 2023, 08:33:23 AM »
The out let has a 1/2" pipe ball valve
I use a funnel to fill the accumulator
Push the piston back with air and fill
It will hols 3L of oil
H Hansel
Honda Hansel
Offline newday777
Re: Oil Pump
« Reply #10 on: December 09, 2023, 11:46:37 AM »
H Hansel
Thanks. I don't know if I'll get an accumulator at the tune of $300+........
Stu
My current rides
Prior bikes....
Re: Oil Pump
« Reply #11 on: December 10, 2023, 05:56:19 PM »
H Hansel
You could always turn that 750 on it's left side and get a little funnel, then pour the main journal full, it would eventually fill in the oil filter, too...
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
Re: Oil Pump
« Reply #12 on: December 11, 2023, 11:24:41 AM »
Re: Oil Pump
« Reply #13 on: December 11, 2023, 04:03:44 PM »
 I've used a gauge adapter a 90* elbow and some pipe fittings to make a standpipe, fill it with oil and let gravity prime it, I've also used an air conditioning compressor oil fill tank, it's similar to the accumulator.
Offline willbird
Re: Oil Pump
« Reply #14 on: January 08, 2024, 02:12:53 PM »
I wondered about somehow pushing oil into that oil gallery to prime an empty pump, good to know that it does work.
Bill
  • Money pit enjoyer
Re: Oil Pump
« Reply #15 on: January 10, 2024, 02:51:07 PM »
I think I'll stick to dripping oil all over my floor and face the Hondaman way.
'77 CB750 SS
Offline BenelliSEI
  • 1969 cb750
Re: Oil Pump
« Reply #16 on: January 10, 2024, 03:03:11 PM »
Good plan.
Offline willbird
Re: Oil Pump
« Reply #17 on: January 10, 2024, 03:36:26 PM »
Good plan.
I am not afraid to try something new :-). Perfect time to try it might be while the oil pan is still off ? On my to do list is drop the pan on my K3 and have a look at the pump. I have a spare pump I got from Ebay.
Bill
Re: Oil Pump
« Reply #18 on: January 10, 2024, 05:28:18 PM »
I've found i like the taste of the Bel-Ray oils better than the synthetics.
Offline newday777
Re: Oil Pump
« Reply #19 on: January 10, 2024, 05:52:30 PM »
Stu
My current rides
Prior bikes....
Offline M_Stone76?
Re: Oil Pump
« Reply #20 on: March 07, 2024, 02:14:37 PM »
Thanks all for the replies , the oil pump is rebuilt and doin a-ok 👌
Only concern is that before I rebuilt it I was getting around 65-70 psi.
Now, I am getting most 60-63 cold.
I’m guessing this means maybe the rotors are worn past their spec? I did not change anything so it doesn’t make a lot of sence, all bolts, rubber, springs etc are new .
The oil stopper valve prevents oil from draining, but doesn’t it prevent too much oil pressure aswell ?
Offline willbird
Re: Oil Pump
« Reply #21 on: March 07, 2024, 05:44:27 PM »
Pressure relief or pressure control valve is what determines maximum oil pressure..same valve but different folks use different terms. Some of the springs in some kits avail now will coil bind without ever letting the valve open.
Bill
Offline M_Stone76?
Re: Oil Pump
« Reply #22 on: March 07, 2024, 07:31:40 PM »
But overall it’s pretty normal ?
I’m guessing the spring is not letting a lot of pressure through ?
Offline willbird
Re: Oil Pump
« Reply #23 on: March 08, 2024, 04:52:00 AM »
The pressure control valve (as I was taught is the correct term) allows some of the fixed volume of fluid to return to the sump in order to control pressure. So a pressure that is lower than desired with the same pump, engine, and oil type/weight would lead me to think that the new spring is weaker. The spring lets some volume OUT.
Bill
Re: Oil Pump
« Reply #24 on: March 08, 2024, 12:43:03 PM »
Did you replace that #@$! shaft seal in between the 2 chambers? If not, the pressure comes out low, and lower when hot.
If your new seal on the pressure relief valve is too tight the pressure goes high, vice-versa if the new spring was not the right calibration - which I have often found in the "kits" sold to rebuild these pumps. I use the old spring, and if the pressure is still lower than 60 PSI at idle engine speed, have added thin shims under that spring to raise the bypass pressure a bit - but, this also involves dribbling more oil...
