Author Topic: Swapping heads Cb650  (Read 842 times)
Offline Hareetmanni
« on: November 26, 2023, 08:24:12 PM »
Hello. So i have 2 Cb650z's both 1980. Other one has been in bits since spring 2023... I refurbished the head fully with new valve stem seals etc. Its like brand new. I want to put that head to my other Cb650 thats driveable. Can i swap the heads? The refurbishment cost me roughly 300€ so i want to put it on to the better bike. And ill get new carbs for it when i have money for it (turns out renovating an apartment is expensive)
Re: Swapping heads Cb650
« Reply #1 on: November 27, 2023, 01:03:53 AM »
There were two different heads on the 650, one with inlet stubs bolted on one with them cast in. As long as both are the ssame you can swap them, with new gaskets of course
Offline Hareetmanni
« Reply #2 on: November 27, 2023, 01:46:09 AM »
Thanks. Ill take the head off the better 650 and look if they are same. Should be. And new gasket has been bought already  ;D
« Reply #3 on: November 27, 2023, 05:06:02 AM »
The carbs were different between the two as well
Offline Hareetmanni
« Reply #4 on: November 27, 2023, 06:56:20 AM »
Yep.  :)
« Reply #5 on: November 27, 2023, 10:24:50 AM »
Bryan:
Do you know when change occurred? Model, or 'type'? I'm supposing it was the 650C engine?
I don't see many of the CB650 SOHC4 bikes around here. I think I've only ever worked on 2 of them. The CX500 seems to have dominated this local market then.
Offline fizzlebottom
« Reply #6 on: November 27, 2023, 01:39:38 PM »
The two different cylinder heads for the SOHC/4 CB650 run were between 79-80 and 81-82. The early 2 years had PD carbs and the later 2 years had CV carbs. These had different spacing. Since yours is from 1980, you would have to have a '79 or '80 head to make sure your current carbs would fit properly. If you used a later head and CV carbs, you'd also have to figure out an airbox solution since they're pretty specific to carb & frame combinations.
1982 CB650SC Nighthawk
2024 Kawasaki Z900RS
« Reply #7 on: November 28, 2023, 07:03:21 AM »
The 650 was not common here either, i just remember seeing both types of head nos on a stall at a swapmeet mate
Offline Hareetmanni
« Reply #8 on: November 29, 2023, 12:16:46 AM »
Both bikes are same year. Same carbs. I was thinking about the head tolerances. But i think these sohc 650's arent so picky
« Reply #9 on: November 29, 2023, 07:38:24 AM »
No Honda is that picky or how would you buy spares?
« Reply #10 on: November 29, 2023, 11:46:05 AM »
You're fine then. Just make sure the cylinder head deck and cylinder deck are both nice and flat.
« Reply #11 on: November 30, 2023, 11:01:39 AM »
If you don't have the equipment or Do not want to buy it and learn, then have a machine shop that does rebuilds of motors measure your head and cylinder block for flatness. The charge is usually worth knowing that you won't be having a failed refresh of the motor.
