« Reply #13 on: December 10, 2023, 03:43:08 AM »
The less 'smart' of a battery charger the better.
I actually have successfully cleaned a couple dozen tanks using a 3 amp smart charger, but I hook it to a shop battery, then have cables from the battery to the tank ground and to the anode rod (bolted to a plastic cup so there isn't direct contact with the metal of the tank and the anode rod.
Yes you have to clean off the rod every 6-8 hours to have the effective cleaning of the rust.
In this case of cleaning rusted bits, you have to hook up the negative alligator clip to the back brake rod/arm surgery submerged in the solution in a plastic bin, with the anode rod draped over the bin edge into the solution so it doesn't touch the metal part.(like in the anodizing videos)
Logged
Stu
My current rides
Prior bikes....
