well its finally done 8 years later . 1part cafe, 3parts psycobilly ,2parts resto, shake it all up ,add spikes and leather for garnish
when i got this 75 cb550F 8 years ago it was totally perfect, orange flake, nice chrome ....i had it just over a month and my buddy wrecked it
...front end was all twisted up, every piece of glass was smashed, and the lower block case was cracked in two places.
if you think thats bad you should have seen my buddy.
This happened while i was in college for welding so i went a little overboard with some of the fab work, because i could.
so here is a basic rundown of the major stuff:
it has a megacycle hardfaced mild cam and rocker arms, megacycle valve springs
new pistos and rings (std size) ,barrnet clutch
mac exhaust, el cheapo pods (saving up for k&ns,and emgo's dont fit the f )
carbs rebuilt w/110 mains 40 slows needle clip second from the bottom
update: the slow jets were returned to stock, way to rich at idlethe frame support under the seat was moved forward 4" the rear fender moved forward 2"
shorty shocks lowered the rear 1 1/2" ,all of the visable welds on the frame were ground smooth
the taillight/plate mount is all hand fabed with simple tools i.e. a ball peen hammer and a welder, and that was for me the hardest part to get right.
center stand removed ,i put a stash tube in the mount for paperwork,
the chain guard is actualy the end of the original guard (welded a bolt to the frame)
new wheels and spokes (david silver) dunlop404's way too many polished parts to name (polishing hubs sucks)
the front end is mostly cb550 from several parts bikes (junk yard)
the gauges are from some other late 70s early 80s honda (swapmeet)
i liked them cause the were a little smaller and black
Update:the gauges are not very acurate ,the tach is off by about 1 and a half rpm at idle (timeing light) not sure how off the speedo is but at high speeds (70+) they bounce like crazy the ignition switch was moved to the crotch area, as was the start button
and the start button on the handlebar was shaved
lots of blood sweat and tears this one guys
sorry it took 8 years
im working on a gallery so you can see all the little details
