Author Topic: '77 CB750F Rebuild.. from parts, seized motor, no title  (Read 377 times)
Offline maxrock
  • 1977 CB750 F2
« on: December 09, 2023, 06:50:35 PM »
Hey guys,
I am in the process of rebuilding a 1977 CB750F from a few boxes of parts, frame and locked up engine. Purchase price was $400 and $50 of gas. No title.
Progress made this far:
- Freed up the engine and disassembled it completely.
- Determined old head was cracked; purchased new head for $120
- Removed valves from old head; determined they need to be cleaned up as does new head surface + combustion chambers.
- Had new sleeve installed in #3 cylinder, cut and existing sleeves honed. $150 incl sleeve, labor and shipping
- Had crank and cam polished, $30
- Purchased engine rebuild kit for $80
So far I'm into this for $830. I still need a) new half shells, b) new bottom end bearings, and c) head/block resurfaced/checked with profilometer, d) chains + chain tensioner. Then I will seal her up and get on with buying more parts ...  Looking forward to fuel savings.......
1977 CB750 F2
Offline Tinman
Re: '77 CB750F Rebuild.. from parts, seized motor, no title
« Reply #1 on: December 10, 2023, 03:05:11 PM »
Looks like you and I are doing similar builds, I have two 750 F's , a 77 and a 78, one will donate parts to the other. Hopefully getting a title won't be too much trouble. Tinman
« Reply #2 on: December 10, 2023, 03:38:31 PM »
Depends on the F model 77 might be F1 or F2, 78 will be F2 and a lot of motor parts do not interchange between F1 and F2
Offline Tracksnblades1
« Reply #3 on: December 10, 2023, 04:42:36 PM »
Hey guys,
Good Luck on your project…
Interesting you 410 cylinder head was cracked…
Do you know where it cracked?
I have 3) spare 410 F cylinder heads. Just wondering where I should be looking for the cracks. I’ve never really seen any post on cracked F2 heads.
Thanks in Advance..
Age Quod Agis
« Reply #4 on: December 10, 2023, 05:26:49 PM »
While it's apart...
1. Check the wear on the valve guides. Almost all of them are worn out by 10k miles. Use bronze guides in place of the old cast-iron type for MUCH longer life.
2. If it is the F2/3 engine, I'd strongly suggest using the top valve spring retainers from CycleX. Ken's fix for the cheap stamped-steel ones Honda used are worth every single cent. They drop right in and will prevent the pull-thru of the valves in those stamped-steel ones Honda used (which are quite worn now).
3. What is the piston-to-bore clearance of the finished pistons and the freshly-bored one? If it is more than 0.0018" it will burn oil.
