Author Topic: CB750K8 Front Fork Rebuild  (Read 527 times)
Offline MrJey
« on: December 11, 2023, 08:26:34 PM »
Hi everyone,
My front fork is in need for a rebuild. The seals are leaking and the chrome on the fork tubes is pretty much gone.
Now, I would like to lower the front fork by 2" and was thinking about shorter fork tubes.
From what I read so far, it seems like the 78' K8 model has different forks!? Does anyone has a recommendations where I could shorter new forks?
I found some on niche cycles but not sure if they would fit and if the quality is right.
http://www.nichecycle.com/ncs/categories/suspension/fork-tubes/cb750-fork-tubes-late-honda-cb750-fork-tubes-late-models.html
Offline newday777
Re: CB750K8 Front Fork Rebuild
« Reply #1 on: December 11, 2023, 10:55:11 PM »
Forks by Frank will make fork tubes to your desired length.
Be sure to reply back of the outcome of your threads you start so they aren't left hanging.
Go to the new members section and introduce yourself and your bike.
http://forums.sohc4.net/index.php/board,58.0.html
Stu
My current rides
Prior bikes....
