Author Topic: CB400 Carburetor O-Rings  (Read 447 times)
Offline grumpy56
« on: December 13, 2023, 07:53:00 AM »
Carb O-Rings - Does anyone know the size of the O-rings used on the fuel interconnects between the carbs and also the fuel line connector between carbs 2 and 3? Are they standard or do I need to locate the "Honda Gasket Sets"? Thanks.
Re: CB400 Carburetor O-Rings
« Reply #1 on: December 13, 2023, 08:55:52 AM »
Ask Nurse Julie a member on here, she sells viton O ring kits for carbs and oil pumps
Offline Kenzo1979
« Reply #2 on: December 13, 2023, 09:02:50 AM »
Pretty sure they are 5.8mm x 1.9mm.  Just order some in Viton.  I’m seeing packs of 10 from a bunch of places, even Walmart.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Offline grumpy56
« Reply #3 on: December 13, 2023, 05:41:55 PM »
Thank you all.
Online Deltarider
« Reply #4 on: December 14, 2023, 12:10:22 AM »
Do they leak? Realise that after a long period of sitting, they shrink. First step would be to open the petcock and... wait. Usually they swell up again to their original dimensions.
Offline grumpy56
« Reply #5 on: December 14, 2023, 06:57:09 AM »
Not sure if they leaked. Have not been used in 10+ years. Wanted to avoid having to rip them apart again if they do leak upon assembly.
Offline Tim2005
« Reply #6 on: December 14, 2023, 11:40:43 AM »
8 x 2mm I think. But, they rarely leak. As your carbs have been empty so long then before installing them and while you have them on the workbench fill them with gas and let them stand a day or 2, you can keep an eye for any leaks and deal with them then, it's much easier than fitting & removing them and it saves any new engine paint getting spoiled
Online Deltarider
« Reply #7 on: December 15, 2023, 06:54:37 AM »
Why did you rip them apart in the first place?
Offline grumpy56
« Reply #8 on: December 15, 2023, 07:03:35 AM »
One carb of the set had a broken float post and another had a main jet post/nozzle that was falling apart. I actually pieced together a full set that is now on bike and this set will be a spare or will sell it.
