Nothing wrong with disconnecting connectors to inspect. If they crumble they need replacing.
There's something wrong with being desperately longing for 'maintenance' and then start messing with things which were better left alone. The number one issue in this forum is... itchy hands.
A relay on the ignition cuts out about five connectors an old fuse box, an ignition switch, the handlebar stop switch and a long length of wiring. Still need a fuse in the line to the relay, but it has given a voltage boost at the coils and definitely improved starting. Recommended!
Wow! Stupid Honda! How could they have missed this?!
In the 70s the performance of Honda's starting was unmatched. When the CB750 was presented on a motorshow in Holland, the Honda importer made it to the TV news, when he demonstrated that just a quick touch of the starter button was enough to bring the 750 alive. He did this right after he had demonstrated how many times he had to step on the kickpedal of a BMW boxer to start
that one.
World on wheels was a well known Dutch television program about cars. In each episode they tested a car. That test always included the socalled 'cold start'. It was performed after that particular car had spent a night in cold storage. As said that program was about cars. I remember
one exception. You've guessed it: they could not possibly have ignored the arrival of the CB750. As expected the bike started rightaway after it had spent a night in the deep freeze. Now, I don't know what 'boost'
your bike needs, but mine can do without. The general rule of thumb in that era was, if your Made in Japan (!) bike does
not start within 7 seconds, there's something wrong. And in case battery voltage would be low for whatever reason, there was always the kickstarter as back up.
The experiment I did, was even
without a relay. Let me explain this. For convenience I have a wire attached to where the battery cable connects to the starter relay. In my situation it's easier to connect a charger there. I don't have to remove a side panel. I made it there because the RH (battery) side is too close to the garage wall. Now I only have to connect the
POS wire from my charger to that little female connector that you can hardly see dangling just below the LH side panel (see pic). The
NEG cable from the charger is connected to the foot peg. Last summer I realised that that same charge wire could be used in an experiment, for a direct line from Batt+ to the
IGN POS. I only had to remember that for the duration of the experiment that wire would be live, regardless whether the ignition was switched
on or
off. Since this was only a test, the risk of forgetting this, was acceptable. If I would find convincing results, I could later fit one of the relays I have lying around.
Glad I did not fit one rightaway. The result was thus, that I concluded I could save myself the trouble. As said, I've seen maybe a slight improvement at idle, but
when riding there wasn't any. None whatsoever.
