Author Topic: Oil leak by exhaust port  (Read 783 times)
Offline katman
« on: December 27, 2023, 05:36:13 AM »
Where should I start looking for this oil leak. I can't seem to find any leakage from valve cover.
Offline Tom R
Re: Oil leak by exhaust port
« Reply #1 on: December 27, 2023, 05:46:27 AM »
Under the cam carrier.
CB750K5 - Slowly putting back together.
GS1100LT - Nicely upgraded over the years.
CB400F - Production lightweight race bike.
Cl175k7 - Gp200 race bike.
Offline denward17
« Reply #2 on: December 27, 2023, 06:07:13 AM »
Agree, probably pucks
« Reply #3 on: December 27, 2023, 06:21:12 AM »
Agree. Usually the puck but on one occasion I also discovered something different. One of the holes that’s drilled and tapped in the head, for the cam carrier screws, came right through into the finned area. Oil was running down the screw threads and into that space.
Clean it up and see how much it’s actually leaking. My K4 has been drooling out the right front corner for a while. It’s so little I just wipe it off occasionally…….
Offline katman
« Reply #4 on: December 27, 2023, 06:33:50 AM »
Yea, this is a slow leak. Has about 300 miles since a top end rebuild.
« Reply #5 on: December 27, 2023, 06:49:15 AM »
Oh boy, if you want it to stop the head will likely need to come back off.
Offline denward17
« Reply #6 on: December 27, 2023, 07:51:28 AM »
The more I think about it, it is probably the cm tower studs.  Were they sealed when the top end was done?
« Reply #7 on: December 27, 2023, 10:07:12 AM »
Remove spark plugs and look in the cavities for oil.
You can hopefully get a finger inside to feel ev oil inside, like the upper part.
Oil can also weep from valve cover gasket if broken. The aftermarket gaskets have usually bad fitting between 2-3 at front. If tighten one of the M6 bolts holding the cover, gasket can or will snapp off. Bad fitting gaskets must be dressed with sharp model knife/ scissor to fit and all bolts have openings for their holes.
I have had an oily front between 2-3 and down due to the breader cover on valve cover. I had forgotten to tighten the front M6, so the o-ring did not seal.
I was surprised that oil weeped against the wind ;)
If more like rubber pucks leaking...
An issue like this is not that big job on a CB750 with frame kit.
Off with valve cover, cam and holders.
Reseal the rubber pucks and check if cam holder studs have been removed. If they have, thread sealer is needed. High temp version.
When doing this retighten all head nuts.  20 ft lbs.
I tightened 20.6 ft lbs with stock studs and fiber gasket.
Lately with HD studs and MLS, 21-22 ft lbs.
« Last Edit: December 27, 2023, 10:16:22 AM by PeWe »
