Author Topic: Obvious sillyness (Oldest tires & sprockets contest)  (Read 5682 times)
Offline Kelly E
  • Geriatric Hooligan
Re: Obvious sillyness (Oldest tires & sprockets contest)
« Reply #50 on: March 06, 2024, 07:10:04 PM »
I changed this sprocket last year and wont win the contest but seems I got my money's worth out of it!
Steve….. I think that might be a winner. Phew!
Maybe give it to Kelly E, make a clock out of it. Its got that cringe factor thing going for it.
I can make a clock out of that. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Mark1976
« Reply #51 on: March 06, 2024, 07:23:35 PM »
There ya go!!!
How do ya not look at that!!!
Start with the end in mind...
« Reply #52 on: March 07, 2024, 07:10:08 AM »
Had I known it was still good for something, I would have sent it to you! It went straight to the bin after the pic was shot...
« Reply #53 on: March 07, 2024, 08:44:58 PM »
 You could have turned that around and gotten another 17 or 18 miles out of it. L0L!
« Reply #54 on: March 31, 2024, 09:53:58 PM »
The rear tyre on the “spare” DT250 was flat, so I went to pump it up, but nada. I removed the old valve and tried to screw in a new one, but there was an obstruction that wouldn’t allow me to screw it in. Turns out a previous owner had screwed another valve deep into the stem, underneath the other one! I’d never seen that before but my valve remover couldn’t reack it. I made another one using a 5mm screw with the thread ground off and aslot cut into it. I still couldn’t get it out so wound it further into the stem then installed a valve and was able to pump it up. The front tyre was badly cracked so I just put 20 psi into it and called it good. In over 50 years of mucking around with old bikes I’ve never seen 2 valves in one valve stem. Luckily I’m taking it to a swap meet next weekend so won’t have to worry about it. ;D
Online grcamna2
« Reply #55 on: March 31, 2024, 10:23:40 PM »
Must have been a powerful valve stem wrench,plus a PO w/ a very weak mind to do something that lame Terry.
« Reply #56 on: March 31, 2024, 11:32:16 PM »
 When the swingarm bolt is wrong and won't reach through the footpeg bracket.
Offline Kelly E
« Reply #57 on: April 01, 2024, 03:05:00 PM »
You should have posted that picture today on April 1st. 8)
1983 Honda CB 1100F
« Reply #58 on: April 06, 2024, 04:46:00 PM »
I'm the fool this April, I sent money to an Italian exhaust company and expected to actually get something in return.
« Reply #59 on: April 08, 2024, 03:11:28 PM »
I read a post in a FB page where a buyer actually received his Busso pipes last week Don, so you never know, you might finally see them soon. ;D
