Author Topic: Cb550-650 Cam Mod  (Read 811 times)
Offline 88BuckMeister
Cb550-650 Cam Mod
« on: January 16, 2024, 08:51:40 AM »
I know there are several posts/topics on this here, but none that specifically answer my question...
It's been made clear "if you want to do the mod, avoid the German export cams because they have a similar profile to the stock 550 cams".
Once I get a 650 cam in my hand, how can I tell to be sure? If I have the serial number on both the bike and engine it came out of, how can I find out if this bike was a German export? Can anyone give me the measurement of the entire INT/EXH lobes so I can use a micrometer to confirm? I measured a new 550 cam and the lobes were 1.368 and 1.340.
I want to be sure this 650 cam I purchased is actually an American 650 cam before I go torquing the head. If there's no clear answer to this question, I'll accept that. Thanks, Buck
Re: Cb550-650 Cam Mod
« Reply #1 on: January 16, 2024, 09:39:46 AM »
I don't have a specific answer to your question.
But does it have a US vin plate on the steering neck and a title? Or was it imported to the states? I see you are in Illinois.
« Reply #2 on: January 16, 2024, 09:48:27 AM »
BTW this probably should be in the SOHC4 Bikes section or the High performance section so a mod might move your 2 posts. Did you hit the notify button so you get an email when someone replies to your posts?
« Reply #3 on: January 16, 2024, 11:31:21 AM »
Here are pics for you
« Reply #4 on: January 16, 2024, 01:21:52 PM »
I literally have a 650 cam sitting on my desk, unsure how you measured but mine is 1.4 & 1.37
Why do you think it might be a German bike?
« Reply #5 on: January 16, 2024, 01:22:44 PM »
That vin tag appears to be a US Model.
I don't have the codes for the plant it was built but the 11th character (M) is the plant.
« Reply #6 on: January 16, 2024, 01:57:37 PM »
I just wanted to know if there was a way to confirm or deny whether it's a German bike. The only thing I've gathered from these threads about doing the 650-to-550 cam mod is that you want to avoid at all costs grabbing a cam from a German export 650 because the cam specs were extremely weak due to environmental regulations on horsepower. The question is once you know that, how in the hell do you determine whether the bike you're buying the cam from was a German export??? haha
Offline Flyin900
« Reply #7 on: January 16, 2024, 02:10:41 PM »
If your in the US and bought the CB650 donor bike or cam in the US then the chance of it being a German export cam is extremely low. Forum members have access to the FSM from Honda on most bikes available N/C (under Manuals and Technical documents) In the section for CB650 bikes you will get the specs for the lobes, with a correct in service spec and a worn out of service spec for the CB650 cam. If you measure the cam you have against those specs it should resolve your concerns on the question.
http://manuals.sohc4.net/cb650/
« Last Edit: January 16, 2024, 02:14:42 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
« Reply #8 on: January 16, 2024, 02:50:43 PM »
Do you know what we need to open up the downloads? My phone isn't opening the files.
Offline scunny
  • don't call me expert
« Reply #9 on: January 16, 2024, 07:10:11 PM »
The service manual lists it as 1.40  1.39. That is the service limit. I can measure my spare, but will be in a few days.
« Last Edit: January 16, 2024, 07:13:15 PM by scunny »
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Kelly E
  • Geriatric Hooligan
« Reply #10 on: January 16, 2024, 07:22:09 PM »
I don't think that they sold the 82' CB 650SC Nighthawk in Europe.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Flyin900
« Reply #11 on: January 16, 2024, 11:01:18 PM »
I don’t use a phone for this stuff only my desktop or IPad and the link opens fine on either device. I believe phones can have issues with different applications though.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #12 on: January 22, 2024, 01:01:47 PM »
I may have gotten an earlier model year 650 cam from an ebay seller overseas.  Or someone snuck in a cam for their build.  Either way, i measured it.  Mentioned in my turbo race build thread
Intakes came up 0.300 on the dial - exhaust was not far behind.  There is visibly more duration than the oem 550 cam.  Didn't write down the open/close marks since there's not much i could do about that for my purpose.  Because of this added lift, the amount of degrees i could safely retard the cam timing was limited to 3° off the stock mark.  Advancing for NA street could be a different story.  Though i have deepend pockets in my race piston and ample deck clearance.  Shes a tight fit.
This cam also required trenching out the oil valley on the head by quite a margin.  Along with some of the ribs in the rocker box.  This must have been cast on a Wednesday or cut with a new grinder guide in the factory.  As my previous 650 cam install was a direct drop in with no clearance issues.
Offline denward17
« Reply #13 on: January 22, 2024, 01:44:29 PM »
Well, I'm confused, I thought you were working on a CB550 engine, not a 650?
Offline calj737
  • I refuse...
« Reply #14 on: January 22, 2024, 02:00:25 PM »
550 motor with a 650 cam swapped in.
Offline denward17
« Reply #15 on: January 22, 2024, 02:05:43 PM »
Right, but his picture on the frame VIN indicates a 1982 650.
Offline Mark1976
« Reply #16 on: January 22, 2024, 02:36:20 PM »
   I believe its the vin tag of the donor bike, '82 cb650sc...
Start with the end in mind...
Offline denward17
« Reply #17 on: January 22, 2024, 02:55:23 PM »
Oh, missed that part.....I'll be quite now...
