Author Topic: Painting 70’ ko upper triple tree question  (Read 1102 times)
Offline slyguy
« on: January 16, 2024, 09:29:55 AM »
I cleaned & removed loose paint. Should I primer & what paint? It seems like it’s a satin finish all its own?
Re: Painting 70’ ko upper triple tree question
« Reply #1 on: January 16, 2024, 04:38:01 PM »
I've read that a semi gloss is close
« Reply #2 on: January 16, 2024, 05:18:40 PM »
Definitely a semi gloss. Honda never primed anything, so you could just feather the edges and hit it again. For a really smooth and lasting finish I bead blasted mine clean, very light coat of zinc chromate primer and a couple of top coats. I probably used Armor Coat products.
« Last Edit: January 16, 2024, 05:33:13 PM by BenelliSEI »
Offline slyguy
« Reply #3 on: January 16, 2024, 06:10:47 PM »
Wonderful, Thanks guys👍
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #4 on: January 16, 2024, 07:12:16 PM »
Dupli Color DE1635 is a spot on match it sprays well and will not cause lifting.
Scuff and feather with gray scotch brite.Clean thoroughly with Naphtha.
I would prefer to media blast and put a couple fresh coats on. It will look better and i prefer not to put paint over paint if at all possible. The Dulpi Color is made to go directly on bare metal.
« Last Edit: January 16, 2024, 09:03:24 PM by Ozzybud »
1976 Z50A PARAKEET YELLOW
1971 CT70H CANDY TOPAZ ORANGE
1973 CL200 CANDY RIVIERA BLUE
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1976 CB750F CANDY ANTARES RED
« Reply #5 on: January 17, 2024, 04:02:30 AM »
Remove all old paint. The old can flake off, an even surface tricky to get.
I used 2k rattle can.
https://www.spraydosen-shop.de...?a=336656&bewertung_anzeigen=1
Maybe not exact match.
I did my other bike's yoke plus a spare.
I painted 3 pilot lamp holders  "dashboard" at the same time.
The rattle can to be used within a few hours.
« Last Edit: January 17, 2024, 04:14:40 AM by PeWe »
Offline willbird
« Reply #6 on: January 17, 2024, 07:16:51 AM »
So is a brand new "dashboard" brown wood grain or were they darker and faded over time to what it looks like in your picture ??
Bill
« Reply #7 on: January 17, 2024, 11:28:54 AM »
Bill
Dashboard is old Honda. Sunbleached. No paint from the very beginning.
I think it was anodized aluminum.
« Last Edit: January 17, 2024, 11:44:58 AM by PeWe »
Offline willbird
« Reply #8 on: January 17, 2024, 02:08:51 PM »
Bill
There are some repro ones avail that do not seem to be brown wood grain around the jewels.
https://z1parts.net/honda-cb750-cb550-cb500-cb350-upper-holder-indicator/
Which made me start to wonder what they actually looked like new in 1972.
More pictures here of one called a NOS
https://www.nospartsnow.com/nos-honda-cb500-k0-cb750-k2-k4-handlebar-holder-pilot-light-box-53133-323-000/
« Reply #9 on: January 17, 2024, 02:41:44 PM »
 I like the VHT roll bar and chassis paint.
« Reply #10 on: January 17, 2024, 09:39:59 PM »
Bill
Yes, that's how they looked like when new. Brushed alu.
Order of lights and text variants depending on year. CB750 K0-K1 did not have this. Idiot lamps in gauges.
The new aftermarket look very cheap when HONDA text is flat, not relief as original.
« Last Edit: January 17, 2024, 10:17:24 PM by PeWe »
Offline Mark1976
« Reply #11 on: January 18, 2024, 06:09:56 AM »
   Same here, the zinc chromate primer was always the base before painting as it promotes superior adhesion to aluminum. Been doing it that way for 50 yrs...
Start with the end in mind...
Offline willbird
« Reply #12 on: January 18, 2024, 08:40:01 AM »
There are quite a few "DTM" (direct to metal) epoxy primers now suited to Aluminum. I used DP epoxy primer on my fork lowers in early 1990's...it is good, there are a few stone chips in the color-clear but the primer is still perfect. But DP is no longer made and the replacement is nowhere as good. Nailing down which primers are ok under which paints can be frustrating but I settled on Eastwood 1:1 epoxy primer with their urethane 3:1 single stage topcoat. It is also confusing because many of the primers intended for direct to metal cannot be used over body filler. The days of good old lacquer primer and every kind of auto body paint going over that fine were far simpler :-).
Bill
Offline Mark1976
« Reply #13 on: January 18, 2024, 10:02:12 AM »
Bill
God, isn't that the truth....
Offline willbird
« Reply #14 on: January 18, 2024, 12:47:02 PM »
Bill
If you start pressing them for answers about  compatibility they will tell you "well you could try it and see what happens" LOL. I bought some SEM primer at first because that seemed like a good choice, but you need a urethane primer over it anyway before a urethane topcoat.....or you could try it and see what happens according the the mfg of the urethane single stage LOL.
Bill
