Hi,
I have just found one of the leads to my front brake light switch had broken. The righthand one, just at the point it enters the bullet connector on the switch. The other lead was also weak.
It looks like they have been stressed from bending as the handlebars move. The two wires enter the main loom under the fuel tank. They seem to just exit from under the tank and make their own way to the switch. The black outer sheath ends just over an inch or so, before the bullet connectors. There may be a bit of interference from the throttle cables. My throttle cables are coming round the front of the steering headstock, to the left side of the underside of the tank. Is that correct?
I've repaired the switch connections. There is still plenty of slack in the brake light switch cable back to the loom, even when the bars are at full right turn. It seems it will only be a matter of time before it happens again?
To check it's routed properly, does anyone have a photo of how the wires route out of the loom through to the switch, round the throttle cables?.
