Author Topic: Alternator Cover Replacement Procedure  (Read 1018 times)
Offline Vintageguy
« on: January 20, 2024, 09:38:02 AM »
Have a 1978 750F. Want to replace the alternator cover. What is a step by step instruction for this? Do I need to remove the cover behind the alternator cover in order to unplug the alternator? I assume this is where it plugs in, but not entirely sure. Do I even need to unplug it in order to change out the cover. Thanks for any/all responses.
Offline BenelliSEI
  • 1969 cb750
Re: Alternator Cover Replacement Procedure
« Reply #1 on: January 20, 2024, 01:29:21 PM »
Does your replacement cover have the “coil” (see photo) already fitted inside? If it does, you just unplug all the wires and swap it over. The harness they attach to does pass through, under the transmission side cover. I usually take it all off for this swap. Good time to give them both a good scrub and change the seal on the shifter shaft.
« Last Edit: January 20, 2024, 01:42:37 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: January 20, 2024, 01:41:13 PM »
If your replacement cover is empty, and you plan on swapping the insides over, take  both covers off. You’ll also find the wires to the neutral switch and low oil pressure switch in there too. You will need a hand held impact driver, for sure. Before you remove the covers, knock the three centre screws (around the HONDA badge) loose. They hold the central, fixed spool in place and are easier to loosen on the bike.
If you are in no rush, watch my 1976 Honda cb750 Project posts. I have to pull both those covers and strip them down, before getting them polished by a local guy. I’ll take a few extra photos and show the step by step, if you want? Let me know.
P.S. I usually replace the section of wire harness that attaches these components to the main harness. You’ll find the original very brittle and stiff. The insulation and outer cover often falls apart when you disturb it. These are cheap at $15-20.
« Last Edit: January 20, 2024, 01:50:07 PM by BenelliSEI »
Online Don R
« Reply #3 on: January 20, 2024, 06:51:18 PM »
 Good idea ^ !
« Reply #4 on: January 20, 2024, 07:06:27 PM »
I might add: there are 3 soft copper washers on those 3 screws that hold the field coil in place: smooth them off gently with a flat file when reinstalling them tightly to the coil in the new cover, lest they weep oil afterward.
Offline Vintageguy
« Reply #5 on: January 21, 2024, 05:49:16 AM »
As usual, excellent, concise, judgement-free advise. Love this Forum. Thanks to all who responded.
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: January 21, 2024, 06:04:00 AM »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #7 on: January 21, 2024, 06:52:25 AM »
If you choose to clean the coil let it dry before installing.
You can clean it with something like mineral spirits to rinse gunk out of it. A light wash off with Brake Cleaner will also work, just don't use anything that will affect the insulation.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline newday777
« Reply #8 on: January 21, 2024, 12:05:44 PM »
Diesel fuel is a good wash to degrease with.
Stu
My current rides
Prior bikes....
Offline Kevin D
  • SE Michigan
« Reply #9 on: January 21, 2024, 12:37:01 PM »
John, I’m going into mine for a starter clutch repair, but I’m looking hard at that intermediate harness.
Mine intermediate harness is 53 years old and it’s never been any trouble. But I can see that wrestling it around might cause a problem. I also worry that replacement parts don’t measure up to OE.
I’ll pay close attention to anything you post up.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline BenelliSEI
  • 1969 cb750
« Reply #10 on: January 21, 2024, 02:28:03 PM »
Kevin…. Good to hear from you. I’ve used a few of those harnesses from vintagecb750.com and they will outlast us both! I’ll add a few photos when I pull the cover, for sure. Cheers, J.
« Reply #11 on: January 21, 2024, 07:31:37 PM »
Me, too: I've used them on several engines and bought one for my own -sometime this winter when it gets a little warmer in the garage(!).
Offline Kevin D
  • SE Michigan
« Reply #12 on: January 22, 2024, 09:10:58 AM »
There are early and late model harnesses offered
From my parts book:
31110-300-000 (Early) s/n ~1132192
31110-300-010 (Later) s/n E-2000001~
I don’t know the differences, think I’m going for the early with 11/70 build E 1068xxx
« Last Edit: January 22, 2024, 09:13:02 AM by Kevin D »
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline BenelliSEI
  • 1969 cb750
« Reply #13 on: January 22, 2024, 11:51:24 AM »
Kevin…. The one I have is listed as;
Alternator Stator Wire Harness, This Harness has the Same 7 Wire Plug as the OEM part and Hooks up Without Alterations. Replaces OEM # 31110-300-154
Offline BenelliSEI
  • 1969 cb750
« Reply #14 on: January 28, 2024, 08:39:26 AM »
Pulled all the covers from my cb750K6 project yesterday. Wrote a detailed procedure. Check out page 13 on my build under Proiect Shop.
Offline Kevin D
  • SE Michigan
« Reply #15 on: January 28, 2024, 06:53:13 PM »
John, thanks for all that writing. Those two posts in your thread, 319 and 320, that would be an hour or more writing for me, plus the photos.
 I’m thinking to service the starter clutch, I will leave the coils in place on the cover, and the aux. harness is upstream.
Covers looking good.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
Offline BenelliSEI
  • 1969 cb750
« Reply #16 on: January 29, 2024, 05:53:12 AM »
[/quot
Kevin…… for your work, you can just “hang” the cover off to one side. Leave it all hooked up and tie it back under the carbs. Have fun! John D.
Offline BenelliSEI
  • 1969 cb750
« Reply #17 on: January 29, 2024, 06:15:54 PM »
Finished the alternator cover today and added a few pictures. See #340 in my K6 Project Shop File.
« Last Edit: January 29, 2024, 06:18:13 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #18 on: February 01, 2024, 11:05:14 AM »
So…. Did you take a crack at it?
