Author Topic: cleaning the crankshaft oil holes?  (Read 621 times)
« on: January 24, 2024, 05:22:24 PM »
 What's the best way to flush out the oil pathways in a crank that's been out of an engine for a while? Or any crank for that matter?
Offline Bodi
Re: cleaning the crankshaft oil holes?
« Reply #1 on: January 24, 2024, 06:09:12 PM »
I use a pressure washer. Wearing a raincoat.
« Reply #2 on: January 24, 2024, 06:15:01 PM »
« Reply #3 on: January 25, 2024, 07:57:57 AM »
 I didn't know this was going to get so personal. That's good info, I missed that on my search.
« Reply #4 on: January 26, 2024, 11:09:49 AM »
 I wonder if that thread could go into tips and tricks?
  I just realized I have a crank that is plugged all the way to the bearings, it's a perfect one to practice on, or maybe even save it. I'll try to get some good pics.
  I didn't get a ball removed yet, but I did drag that old crank out and run a drill through the oil holes that I can reach. The balls on this one stick out so far that I'm surprised tapping them with a small chisel didn't knock one out. I did polish a main with used 400 grit and it cleaned up well.
« Last Edit: January 27, 2024, 11:25:41 PM by Don R »
« Reply #5 on: January 27, 2024, 11:27:48 PM »
 Here's a picture of a muddy rod journal. I think this happened while sitting, the bearings aren't spun or worn out, they just are coated with whatever was in the oil.
« Last Edit: January 27, 2024, 11:29:58 PM by Don R »
Offline Tracksnblades1
« Reply #6 on: January 27, 2024, 11:45:24 PM »
Looks similar to the accumulated sludge in a centrifugal oil filter…
Perhaps your balls were leaking a bit…😁
Age Quod Agis
Offline M 750K6
« Reply #7 on: January 28, 2024, 12:45:50 AM »
I had a lot of that in the bottom of my oil tank. Oil overheating and irregular oil changes at some point of its life.
Offline Mark1976
« Reply #8 on: January 28, 2024, 10:35:24 AM »
Not something I thought I would hear on a bike forum. But, yeah, what he said...
Start with the end in mind...
