Author Topic: Piston ring install  (Read 367 times)
Offline pablo63
Piston ring install
« on: February 07, 2024, 07:25:18 PM »
Hello
   I am doing an engine re-build on a 1972 Honda cb 350 four ,I purchased an engine re-build kit from 4 into 1 which included the piston rings .Unfortunately it came with no instructions for the two compression rings as to which one goes on top & also there are no markings on the rings .Of the two there is one which is rectangle & the other is beveled on both edges of the outside ,just wandering if anyone has used these rings and what is the correct order.
Thx
Re: Piston ring install
« Reply #1 on: February 07, 2024, 08:07:53 PM »
Normaly the top ring has a chrome colour to it and also normaly markings go upwards, if the vendor can not give you suitable fitting instructions i wouls ask for return and refund then buy from a more helpfull seller
Offline newday777
« Reply #2 on: February 07, 2024, 08:08:29 PM »
I haven't used them from 4into1.
The beveled usually goes in the top groove.
If you look closely at the other it should have a slight angle on the edge(not an actual rectangle).
They both should have a dot on the upper surface of the rings to show the top.
Stu
My current rides
Prior bikes....
Offline CycleRanger
  • No comment about being an
« Reply #3 on: February 07, 2024, 08:23:06 PM »
From 4-into-1 website.
https://4into1.com/piston-ring-set-standard-13011-333-003-honda-cb350f-1972-1974/
The Honda shop manual has illustrations showing how to orient the bevel.
« Last Edit: February 07, 2024, 08:25:06 PM by CycleRanger »
Offline pablo63
« Reply #4 on: February 08, 2024, 04:14:33 PM »
Thx for the response ,got it figured ,the 4 into 1 website had a description for the ring install
