Author Topic: can't get her reving  (Read 1335 times)
Online calj737
  • I refuse...
Re: can't get her reving
« Reply #25 on: January 29, 2024, 05:22:17 PM »
Oil doesn't burn black like fuel. ;)
Oil-soaked plugs certainly can be black. As I said, it might be a condition. I did not say it was.
Offline Tracksnblades1
« Reply #26 on: January 29, 2024, 06:29:09 PM »
What about the obvious??
What does the smoke “coming out of all 4 pipes even after shutting it off” smell like..?
Does it smell like oil burning ? Or the smell of an engine trying to run on full choke ?
Do you have any automotive engine experience?
Age Quod Agis
Online willbird
« Reply #27 on: January 30, 2024, 07:31:06 AM »
It sounds to me as if the new rings have not properly seated yet. Co worker had a small block chevy that had a bad fuel pump, it was leaking fuel into his oil, this prevented the rings in the newly rebuilt engine from ever seating. He ended up fixing the fuel pump issue then had to tear it down, re cross hatch the cyl, and use new rings.
Or perhaps one of the rings is installed upside down ??
Bill
Offline greg
« Reply #28 on: January 31, 2024, 03:02:01 AM »
black and wet. my interpretation of that is too rich, right?
Not necessarily. Could easily be oil-fouled. Any chance you could perform a leak down test? Do you mind providing specifics of what head work was done? Valve seals, guides, valve seats re-cut?
Hi calj737!
I've done following head work
- new valve seals
- nothing on the guides
- seats were lapped (by hand)
Once the work was done I turned the head over and filled the valve area with soapy water. Applied pressured air in to the exhaust and inlets.
all tight there, no bubbles
Offline greg
« Reply #29 on: January 31, 2024, 03:04:04 AM »
Plug wires screwed into caps properly? 1-4 and 2-3 wires to right coils? Fuel line blocked or kinked?
I’ve seen these simple fixes solve big problems in the past. Fast and easy checks.
Thanks Tom!
I was thinking onto that direction as wwell already. Iwill double check if the coils (yellow and blue wire) are hooked up right.
I can already rule out plug wires and fuel line
Online willbird
« Reply #30 on: January 31, 2024, 12:30:12 PM »
Thanks Tom!
I am not too ashamed to admit that I did not know at first that the wires screwed in.
Bill
