Author Topic: What is THIS and does it need replacing?  (Read 982 times)
Offline 88BuckMeister
« on: January 29, 2024, 06:27:43 PM »
Can anyone tell me what this is and whether a piece of it being chipped off warrants replacement? Thanks
Offline grcamna2
Re: What is THIS and does it need replacing?
« Reply #1 on: January 29, 2024, 10:01:34 PM »
Do you have a close-up pic of the damage ?
75' CB400F/'bunch o' parts'
« Reply #2 on: January 30, 2024, 12:10:27 AM »
Its a blanking plug, yes if it leaks oil, caused by an O ring chain and to do it properly you split the crankcases
Offline M 750K6
« Reply #3 on: January 30, 2024, 12:29:14 AM »
That's a good spot. 👍
Online carnivorous chicken
« Reply #4 on: January 30, 2024, 06:16:23 AM »
This.
It's possible to patch it and run it -- I think I used JB weld on mine years ago and it held up (preventing that annoying drip that comes through the cover onto the shifter). I put a small washer behind the sprocket -- changed the geometry of the chain just a little, I'm sure adding to some premature wear, but it worked for me.
Offline Deltarider
« Reply #5 on: January 30, 2024, 06:40:31 AM »
The ones I have seen, did not leak.
CB500K2-ED Excel black
« Reply #6 on: January 30, 2024, 09:09:35 AM »
Looks like maybe the sprocket wore into it? It doesn't look cracked now that I look at it. It looks ground into by something maybe either the sprocket or the chain???...
« Reply #7 on: January 30, 2024, 09:43:03 AM »
Not the sprocket, as i said an O ring chain or extra wide chain
Offline Mark1976
« Reply #8 on: January 30, 2024, 10:18:04 AM »
+1...
Start with the end in mind...
Offline grcamna2
« Reply #9 on: January 30, 2024, 10:46:53 AM »
You may be able to fix that blanking plug using case sealer;either Hondabond or Yamahabond.
Offline Captainkirk
  • Certified bike nut
« Reply #10 on: January 30, 2024, 04:19:03 PM »
It wasn't leaking before. I second the Yamabond or JB Weld idea over splitting the cases (yikes!)
It's easier to ask forgiveness than to gain permission.
