Author Topic: Electrical panel missing component? Starter motor safety unit  (Read 647 times)
Online denward17
« on: January 31, 2024, 07:34:27 AM »
A previous owner appeared to have cut 2 wires near the electrics base panel, G/R and LG/R.
Tracing the wire diagrams it appears the G/R goes to the clutch switch, the LG/R goes to the neutral lamp indicator.
Where do these wires connect at the electrics panel?
76 CB550K
Re: Electrical panel missing component? Starter motor safety unit
« Reply #1 on: January 31, 2024, 08:59:41 AM »
To the starter safety interlock circuit or diode
Online denward17
« Reply #2 on: January 31, 2024, 10:27:27 AM »
Thanks Bryan, it appears that part was taken off the bike.  It is anchored at the top right of picture in that stay that has nothing in it.
I got a diode ordered, Thanks again.
« Reply #3 on: January 31, 2024, 10:51:05 AM »
Den,those wires/plug go to your silicone rectifier and your bike needs it to charge.
« Last Edit: January 31, 2024, 11:05:00 AM by grcamna2 »
Online denward17
« Reply #4 on: January 31, 2024, 12:45:00 PM »
^Thanks Bill, does it matter which wire goes to + or -  ?
« Reply #5 on: January 31, 2024, 12:58:20 PM »
Wrong! The diode replaces the older Starter Motor Safety Unit, which prevents the electric starter from operating unless the trans is in neutral or the clutch lever is pulled in; it has nothing to do with the charging system.
Den, it does matter which wire goes where.
« Reply #6 on: January 31, 2024, 01:46:50 PM »
Ooops  :o  I stand corrected.
« Reply #7 on: January 31, 2024, 07:32:54 PM »
The light green/red wire goes to the + side of the diode (the arrow on the diode symbol points to it), and the green/red wire goes to the - side. If you get it wrong, nothing bad like smoke and fire will happen, it just won't work as designed. ;)
Online denward17
« Reply #8 on: January 31, 2024, 07:37:39 PM »
Thanks Scottly!
I did find a '76 wiring harness on Ebay for $30, so I jumped on it.  I know I could probably find the connector somewhere like vintage connections, but like the idea of having a spare wiring harness anyway.
Online denward17
« Reply #9 on: February 03, 2024, 06:57:38 AM »
Ebay deal fell through, seller indicated this one was damaged by fire.
« Reply #10 on: February 03, 2024, 07:00:20 AM »
I got some vintage connectors to use when needed, very handy
Online denward17
« Reply #11 on: February 03, 2024, 07:02:00 AM »
I got a few spares as well, hoping I have a couple to fit the diode when it gets here.....
Offline kerryb
  • Not a very
« Reply #12 on: February 05, 2024, 10:58:06 AM »
I bought a generic diode from spark moto and attached it to those two wires, works good.
Online denward17
« Reply #13 on: February 05, 2024, 11:05:14 AM »
Thanks!
Hoping the one I connected will work, will find out in a few months...
« Reply #14 on: February 06, 2024, 12:08:48 AM »
Did any of you complete this safety idea by adding a forgotten lowered sidestand in the scheme? How would that wiring look like?
