Author Topic: plug wires  (Read 1743 times)
Offline hymodyne
plug wires
« on: June 15, 2005, 07:50:06 AM »
I've looked at posts concerning wire splicers for spark plug wires. I've also heard that the plug boots that attach to the plug can go bad. Can I use standard automotive wires on my bike if I splice them, and can I use the traditional soft spark plug boot like the ones used in automotive applications?
hym
Offline dusterdude
Re: plug wires
« Reply #1 on: June 15, 2005, 08:37:26 AM »
i used automotive mettalic core wires on mine,however i did use the ngk caps
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Salem350F
Re: plug wires
« Reply #2 on: June 15, 2005, 11:26:19 AM »
I used a  NAPA metalic core universal  kit on my 350F  I retained the factory molded ends in that I was having a lot of trouble with the NGK caps.  I spliced the wires at the coil with solder, 3M fusion tape with heat shrink over the splice.  Seems to work Ok
Offline dpen
Re: plug wires
« Reply #3 on: June 17, 2005, 03:29:25 AM »
I used automotive copper core wire. Solder the wires, coat with silastic & then heatshrink. I kept the the NGK caps as they're easier to get at on a CB750.
