Author Topic: NOS Honda cb750 Engine/Trans.  (Read 1633 times)
Re: NOS Honda cb750 Engine/Trans.
« Reply #25 on: February 24, 2024, 11:47:31 AM »
Points look square and new…… I wonder if it just got a “bench test”. The story is it was sent to a dealer as a warranty replacement and never installed. I will pull the cam cover at one point and see what the cam and rockers look like.
Any other suggestions?
« Reply #26 on: February 25, 2024, 08:54:13 AM »
Anybody need this? Not sure what I’m doing with it……
Online Tracksnblades1
« Reply #27 on: February 25, 2024, 07:21:01 PM »
Wondering why it has intake rubbers and clamps for the carbs….?
T do you think it’s  a take out instead..?
The way the wire is cut…?
« Reply #28 on: February 25, 2024, 07:50:11 PM »
Honestly don’t know. Could be. Will have a look and see what the cam/rocker wear looks like. Maybe pull the pan too?
« Reply #29 on: February 25, 2024, 08:46:28 PM »
Where as the motor has stamped vin, I would suspect it was a warranty take out for some reason and would probably want to tear it open to do a close inspection on it. It could be on the power side or the out put of the transmission.
« Reply #30 on: February 25, 2024, 08:48:10 PM »
I wonder if you contacted Honda warranty claims if they could do a search on the vin to see what was the reason for it being replaced.
« Reply #31 on: February 26, 2024, 05:33:46 AM »
Stu….. Honda started selling Civics here in 1976. There were about 10 people in the “Auto Division” and 2 or 3 distributing the motorcycles. I’ve tried in the past, with no results.
« Reply #32 on: February 26, 2024, 05:41:53 AM »
Understood. 1976....pre computer and no input to the computer programs. Hard copy files only and most were deep sixed long ago even if the dealer is still in business.
« Reply #33 on: February 26, 2024, 07:05:33 AM »
Might make a cool go-cart or golf cart.
« Reply #34 on: February 26, 2024, 07:16:05 AM »
+1...def does not look like a "new" motor.    Do you happen to have [or can borrow] one of those borescopes to look inside?
« Reply #35 on: February 26, 2024, 12:27:57 PM »
I have an old one that may work. I think the cam and rocker gear might tell a story too? No use for it, bought on a whim!
I thought about putting it in a golf cart. The challenge would be reverse gear and adequate cooling……
« Last Edit: February 26, 2024, 02:35:10 PM by BenelliSEI »
