Author Topic: Replacement electrical wires  (Read 580 times)
Offline lash
« on: February 14, 2024, 06:48:39 AM »
Any ideas on where to buy wire with the proper colouring, ie. green with red stripe.. to restore original wiring?
Re: Replacement electrical wires
« Reply #1 on: February 14, 2024, 06:55:55 AM »
New wiring harness might be a better bet. Hard to rebuild an old harness. For example, where mine went up to the headlight it was very stiff and crispy.
Offline lash
« Reply #2 on: February 14, 2024, 08:17:38 AM »
I’m trying to rebuild handlebar switches..
Online calj737
  • I refuse...
Online newday777
« Reply #4 on: February 14, 2024, 09:36:25 AM »
Get a used/hacked wire harness and solder and heatshrink, as long as you are good with soldering.....
I've bought a couple of parts bikes that harnesses were compromised that were good for cutting and splicing, which I've done on a few harnesses.
On my K8 I used another harness from another K8 frame, both harnesses had problems at opposite ends, so I staggered cut the wires in the center after removing the tape covering.
If I get around to bringing those other bikes without a harness back to life I'll buy a replacement harness.
« Last Edit: February 14, 2024, 09:38:13 AM by newday777 »
Online newday777
Offline lash
« Reply #7 on: February 14, 2024, 12:25:19 PM »
Dwayne…., I have two or three harnesses I pull apart whenever I need a bit with a specific colour and end. You’re welcome to them. J.
Offline lash
« Reply #8 on: February 14, 2024, 12:52:36 PM »
Might take you up on that. Right now I am putting the engine back together so a while to get to the switches.
Offline Tim2005
« Reply #9 on: February 14, 2024, 01:09:08 PM »
https://lswiring.com/collections/wire?page=2&pf_t_type=TXL+Wire
That's a great link. Do you know how the wiring gauges run- what gauges would be needed for say a low duty wire/a headlight wire/ a main fusebox feed wire?
Offline willbird
« Reply #10 on: February 14, 2024, 01:26:29 PM »
That was my first thought was that they have 22 gauge wire which I bet would be fine for that purpose. A quick google told me 150-200 mA is what the coil in a relay typically draws. A coil that ohms at 72 ohms would have that amperage draw.
Bill
« Last Edit: February 14, 2024, 01:29:51 PM by willbird »
« Reply #11 on: February 14, 2024, 02:22:54 PM »
Anytime. I need to return your engine stand and have one side cover too. Looking for anything else? I can post you a harness anytime. J.
Online calj737
  • I refuse...
« Reply #12 on: February 14, 2024, 08:01:18 PM »
18awg would be my recommendation to carry that current. 22awg I reserve for ground wires from momentary switches as an example. It might rate as suitable, but it’s so much smaller than stock it becomes a bit of a nuisance for integrating to the stock loom.
Offline willbird
« Reply #13 on: February 14, 2024, 08:30:55 PM »
I misunderstood, I thoght he was asking about the signal wire for a headlight relay.
Offline Tim2005
« Reply #14 on: February 15, 2024, 11:10:39 AM »
I just meant generally, what different gauge wires should we use for the different levels of load of our sohc4s electrical components
Offline willbird
« Reply #15 on: February 15, 2024, 11:58:28 AM »
Indeed, and it is fairly popular to put loads such as headlights on a relay so that the switch has an easier job :-). Having the correct color of a smaller gauge wire just for activating the relay would be cool :-).
Offline Gurp
  • I'm no.......
  • Once was a...
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
